Some thing different for me to work on, questions.
#1
OFFLINE
Posted December 01, 2015 - 01:55 PM
Anybody have one of these. ?
- boyscout862 and Dieselcubmike have said thanks
#2
OFFLINE
Posted December 01, 2015 - 04:53 PM
Left out in cold, so won't do what you want for you?? Heh! Would think most of those type tractors have a little alternator seperate from engines? No? Haven't a clue, so no help here. Parts easy to get at New Holland then? I have looked at some of those way back, but never could spend the money or else it was kinda worn out and didn't want. I like the 3cyl better than the 2 also, not sure when that changed or models.
- propane1 said thank you
#3
OFFLINE
Check the connections, have you load tested the battery, what is the voltage at the battery when it's running. Does it have a separate voltage regulator, generator or alternator?
#4
OFFLINE
Posted December 01, 2015 - 06:03 PM
How does one bleed the fuel system or do you have to, when it's restarted. ? Oil furnaces have to be bleed to get the air out, from what I remember. Changing fuel filter. Is there a port to open to allow air out from gravity or do you have to turn it over to get pump pressure.
Thanks for the help, Noel.
#5
OFFLINE
Posted December 01, 2015 - 07:49 PM
tires on backards again.. shoot!
#6
OFFLINE
Posted December 01, 2015 - 08:43 PM
I would fill the filter full of fuel before you put it on save a big headache trying to bleed it out.
Pete
#7
OFFLINE
Posted December 01, 2015 - 08:54 PM
#8
OFFLINE
Posted December 01, 2015 - 08:56 PM
