The Clutch Bolens Forgot
#16
OFFLINE
Posted December 02, 2015 - 12:13 PM
#17
OFFLINE
Posted December 02, 2015 - 03:44 PM
Could probably be done but would take a lot fabrication. The drive shaft is direct from engine to hydro and ol;ly about 18" long. All fits kid of tight where it goes through. No room at the engine or the hydro so would have to go in between some place.
The diesel Cub Cadet super tractors had one that went in the middle of the drive shaft and worked kind of like the compression release in the Kohlers. I think they were about 8 or so inches across and had a 1/2" or 5/8" drive shaft. Here's the parts breakdown on it. Stewart
#18
OFFLINE
Posted December 02, 2015 - 04:35 PM
Something like that would be great. Bolens have a large tube type drive shaft but could still be done. I went out this afternoon and pulled that 6 hp
Briggs out and set it on the bench. 2 pulls and it was running so it is not the engine. Let it run a while to warm up good, then put it back in the tractor. All I could get 3 or 4 pops. I know I am not near as strong as I used to be and with bad shoulder I can't do near as much but gosh, this is ridiculous. Those hydro's must really put a drag on the engines when they are cold. Was 39° so wasn't all that cold this afternoon.
#19
OFFLINE
Posted December 02, 2015 - 06:49 PM
That is an eaton 12? I don't know those. Is there a freewheel pin/switch? If not, are the wheels off the ground? Does the hydro share fluid with the final drive? Nice thin ATF-type fluid in there?
Paul
#20
OFFLINE
Posted December 03, 2015 - 12:05 AM
That is an Eaton 12 in a 1476 provided nobody ever changed it to something else. If it is the correct hydro, there is a neutral position in the middle on the selector that allows the hydro to spin easier.
