Sears SS15
86 replies to this topic
#61 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 24, 2015 - 06:35 PM
I am worried about a draw but who knows , I am going to hook up the battery and try it tomorrow like it sits , what's the worst could happen , maybe a melt down
#62 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 25, 2015 - 08:59 AM
Many thanks to all especially Craftsmanmowerfreak ,  for a great Christmas present !!!!!!!!!!!!!!!!!!!!! went out there this white Christmas morning , heavy fog and 70 degrees , put the battery in and hit the key for 1/2 a second and it is running , shows charge on the amp meter , hooked a meter to the battery and show 14.3 volts , wow , it cost about $240 for all  new parts : battery , starter/generator , pulley , regulator , key switch , solenoid and a cable , well worth it ---------what I need to do now is a battery hold down , got a bungie cord on it now , OEM is no longer available , going to have to fab something up
#63 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted December 25, 2015 - 09:10 AM
Glad to hear your back up and rinnung!
Not sure how your setup is but i do have universal battery holddowns that I use on my Bolens
http://bolenspartsan...ely-wheelhorse/
#64 KennyP ONLINE
  • 38,417 Thanks
  • 45,945 posts
Posted December 25, 2015 - 09:16 AM
That's good news!
#65 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 25, 2015 - 09:27 AM
What a combo , 1972 Tractor which had a 15 hp Briggs , now has a 1989 16 hp Briggs , 1972 15hp starter mount modified to fit the 16 block , 1972 starter , a little of the 1972 wiring and a bit of 1971 14 hp wiring and regulator , upgraded with a solenoid added in
#66 TAHOE OFFLINE
TAHOE
  • 7,977 Thanks
  • 5,676 posts
Posted December 25, 2015 - 09:46 AM
Great to hear it's running.
#67 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 25, 2015 - 09:48 AM
That looks really good  ,   Bolens  1000
#68 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted December 28, 2015 - 08:47 PM
ill try to get pics of a stock one if i remember 1/4 inch threaded rod bent to look like pic i will be taking and ur good to go
#69 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 29, 2015 - 07:36 AM
What about the drive belt , it needs a new one , is there a better quality belt to use , like maybe one of the green thread wrapped belts
I am going to refurbish the mover deck next , the housing isn't in that bad of shape , thinking of using a pressure washer sand blasting gizmo I have , would need bearings in two spindles and one complete spindle and three new blades and a belt  ------- I seen a kit on e-bay for the deck I have , comes with 3 spindles , 3 blades and the belt for like  $180 , would make a good back up for my Husqvarna 5225 Zero Swing
#70 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted December 29, 2015 - 11:28 AM
drive belt go to tsc and get one those huskee blue 5/8x82 inch belt
#71 Bolens 1000 ONLINE
  • 14,987 Thanks
  • 18,140 posts
Posted December 29, 2015 - 11:34 AM
Make sure you get a kevlar reinforced one, the auto store belts are only for automotive applications like running a fan belt.
I have been selling the red kevlar cord american belts with good results for these machines.
#72 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 30, 2015 - 06:14 AM
Thanks again , red kevlar or blue huskee , both  something I have not yet experienced , 5/8 x 82 really helps ------
I love this tractor , I have had riding mowers but never a tractor , I keep going to it and hitting the starter to see if the battery draws down and it starts in 1/2 a second with no choke and at idle every time ,  I use to pull the grade rack with my 4x4 ATV on chains to keep the driveway graded and weeds from coming up and it didn't do as good a job and as easy ------------ saves me on round up alone  ----really looking forward to use it on a food plot I plan on building for next years deer season
also want to build a receiver hitch attachment to the 3 point hitch as I have a lawn sweeper , utility trailer and a log splitter with a hitch on it , I have some square tubing and a receiver socket , seen a few pics on the net ,  any pics of a nice set up ?
#73 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted December 30, 2015 - 01:14 PM
i run the tsc belts and never have a failure because of belt. i run them on everything
#74 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted December 30, 2015 - 01:29 PM
here are some pics
#75 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 30, 2015 - 07:33 PM
Thanks  for the pics ,  knowing what it looked like really helps ------  I learned a long time ago about automotive belts on my riding mowers , they didn't last no time , seems like it was one every year and then I got a green thread wrapped that I think was made by Gates as it was from NAPA , I think it was called a  Lawn Equipment belt and I never changed it again ,  got the info in a folder some where ---------- tsc , where do you get them from ????
