Sears SS15
86 replies to this topic
#31 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 258 Thanks
  • 222 posts
Posted December 01, 2015 - 07:19 PM
ummmmm find the model number type and code from your engine i notice it dont have points which means engine is 82 or newer
#32 Georgia SS OFFLINE
Georgia SS
  • 39 Thanks
  • 29 posts
Posted December 01, 2015 - 07:59 PM
Hey Guys
 Been reading about the SS15 engine swap, all seems well, but sure do hate to see you cut an aluminum grill, no a lot of them around still good, i put a 20Hp onan in place of my 15 briggs, hood got a bit low and grill was too close so looked at the GT18 lower grill mount, copied it with 3 6" peices of 1/8" by 1 1/2" flat, moved the grill up 1 1/2" and bottom mount forward 1 1/2" give the grill a bit of staight up look, the oil drain would go right under the aluminum grill with no cut, also helps with muffler clearence. I think a vent hole in the fill tube was mentioned, on my roper with the 13HP briggs the pulse pump connected there,it had the tank under the seat.
Have A Good One
Jimmy
#33 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 08:11 PM
for the most part every thing looks the same on the print , the tractor has a decal from a Briggs and Stratton dealer , who I would bet did the motor swop ,
 the engine is model 326431, type 2520-01 . code 8900514 , 16hp , I had no idea what year the engine was , so you think it is an 82' ,
not a vintage matching serial number tractor ,  but I can live with it
I really like the site , I got more info in a few days then I got in the time I have had the tractor
#34 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 258 Thanks
  • 222 posts
Posted December 01, 2015 - 08:31 PM
code says 89 lol wow i didnt know they made cast irons still in 1989
#35 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 02, 2015 - 05:19 AM
One thing I find hard is I have to bend over backwards to reach the 3 point hitch raise lever ,  I thought about heating up the rod and bending it forward some , but I don't really like that idea ---------- I thought about splitting a piece of pipe in hallf that will saddle fit over the handle (rod) and clamp that with u-bolts , weld and extension( about 3 inches )  to that and a new handle to the other end , you could loosen the u-bolts and slide it right off .  Or maybe a piece of pipe that would slide over the handle and build from that ------------- Any ideas on a 3 point hitch raise  lever extension ???????  -----I have seen a couple of videos of people who have made electric actuator 3 point hitch lifts , whats the pros and cons on that ????????
#36 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 258 Thanks
  • 222 posts
Posted December 02, 2015 - 08:38 AM
they made a extension handle if you do some digging. i have the stuff to make a couple if i get the time this spring. but yesafter a while you get used to where 3 point is. wait til you find a tiller. i got the big 39 inch 3 point tiller lol watch this video
#37 TAHOE OFFLINE
TAHOE
  • 7,604 Thanks
  • 5,518 posts
Posted December 02, 2015 - 09:48 AM
Thank you so much Craftsman' , I am going to give my guy at the starter shop a call and see if that does anything for him , I am hoping he can build me one ---------the bike in the back round is a classic and I think very rare , we are heavy into ATV's and machines that run in the dirt , I like to fish but my real hobby is  wet dirt , it is a 1973 1/2 Honda Xl250 with a 250 MotorSport engine , last year and they tuned them down  , with an ATV wheel kit on it which I believe was made by Missile Engineering  , it sat in a barn till 3 years ago from 1975
That is pretty sweet! I remember those big wheel ones that Honda produced about the same time as the Trikes, always wanted one.
Here is the factory Sears 3pt handle extension.
I have also seen guys just bolt a long straight handle to the 3pt handle for extra leverage like in my kindergarten style  painted pic below :D
Edited by TAHOE, December 02, 2015 - 09:53 AM.
#38 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 02, 2015 - 06:49 PM
Nice video , makes me want to go dig something up  , " I was singing along " What they call work , digging in the dirt , to get the crop in the ground , before the rain come down " , that's good song , you know it ------ Boys 'round here ", Blake Shelton
I talked to the starter guy and it sounds reasonable , $160 total for a new Starter /generator , regulator and he will supply the pulley as I gave him your link to the 15 on ebay and he seen the pulley and says he has one that will work ---also got the wiring diagram from your link , that was sweet , couldn't print from that so I took a pic of the screen with my phone and sent it to my computer and printed it , thats is going to come in handy , Thanks again , you made it so easy
the front tires on the tractor pulling the plow , what size and brand are they ? I like them
That's almost exactly what I was imagining on the extension , thanks for the pics , going to get on making one of them
The bike you might be thing about was the Honda Fat Cat , 200cc , they only made them like 2 years 1986 and 87 , I always wanted one too , I had planned on doing the Honda 250ES or R 3 wheeler into 2 wheeler conversion when this bike found me , Yamaha also had one and still has a version of it today , the story I got from the old man that had it , his son bought the stock bike mid 73 and in 75 he sent it to California and had the kit put on at a shop , I think these kits were way before the Fat Cat , the front wheel bearings were welded into the custom rim and when they went out he parked it , I did a lot of custom work to the front rim , and the bearings are much heavier and replaceable , relocated and hosed the valve stem , got the speedometer working , the bike is street legal but not highway with those tires ,  it has been a fun project and fun to ride  , it's broke down right now ,  I need to split the case and replace the main shaft as I stripped out the  spline where the sprocket rides ,  I got the shaft , all parts and gaskets , just got to find the time
Another project I am doing right now is pretty cool , a Ezgo WorkHorseST350 cart , with 14 1/2 inches of lift , disc brakes , a Honda Fourtrax shaft driven engine /drive train with 27 inch ITP Black Water tires , it's about 60 ++ % complete , want to see a pic
  • TAHOE said thank you
#39 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 258 Thanks
  • 222 posts
Posted December 02, 2015 - 07:07 PM
those are 4.80-8 carlisle super tracs they were from a sears tiller and they even says sears on them instead of carlisle. but i know who made them for sears lol. thats my dads tractor its about 140 lbs lights than the suburbans lol mine was one pulling the tiller
#40 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 13, 2015 - 06:32 PM
The starter /generator , regulator and pulley , has been at the shop for about a week now , hope to pick it up this week , finished the mounting bracket modification today , used a 15 hp bracket on the 16 hp engine , had to cut out a place for the hump that a 16 has and  a 15 don't so it fit flush against the block , then reenforce  what was left of the bracket by welding  it up with some gussets  , all I need is the belt
  • craftsmanmowerfreak said thank you
#41 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 15, 2015 - 07:36 PM
one more step closer to electric start , hoping to pick up the starter/generator tomorrow as I plan on being within 2 miles from the starter guy , when they are 55 miles away from home , I try to make every mile count
#42 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 17, 2015 - 06:20 PM
Got the modified 15hp starter mounting bracket bolted to the 16 hp engine and the starter /generator , regulator and belt  mounted ------
the regulator has an extra terminal on the bottom side of it ?????? ----I need another solenoid for the starter and a battery , does any one have any part numbers and battery Group size to go with , they was one bolt on style positive terminal on a cable , but think it could have been bolt and lug style battery to start with ??????  the Auto Parts couldn't match the solenoid or the battery
#43 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 258 Thanks
  • 222 posts
Posted December 17, 2015 - 06:30 PM
ok match the letters to the old one run wires to the terminals extra terminal is for lights lol brown wire if i remember goes to terminal underneath if you reread earlier post you would of seen this :)
Edited by craftsmanmowerfreak, December 17, 2015 - 06:32 PM.
#44 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 258 Thanks
  • 222 posts
Posted December 17, 2015 - 06:36 PM
also 4 terminal regulater are used one sears 71 and older i perfer the 4 terminal ones anyway the lights dont turn on without key on using older regulater means if a kid is around and flip lights on you wont have a dead battery lol
#45 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 17, 2015 - 07:18 PM
This one is wired a little different for the lights then you describe , it all looks stock and matches the wiring diagram that I have for my model number except there is no 4th wire , the new regulator has a terminal marked "L" and from that terminal the wire goes to one side of the amp meter where another wire branches off to the light switch -------- I think what I sure do is screw a lead to the underside terminal before I tighten up the regulator mounting bolts so i can get to it easy later ------ any ideas on the battery group that is suppose to be in there never had one to start with ????
