Sears SS15
86 replies to this topic
#16 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 06:16 AM
I would  appreciate  that , Craftsmanmowerfreak , being a heavy equipment mechanic for 40 years next year I have sources for the parts , my starter guy tells me he could put something together for me , but I would really like to be sure the amperage , pulley diameter and belt width  is right and I would like to give him a part number to work with , he did tell me that were not many to pick from
The guy I got the tractor sold it cause he couldn't get it running right , I found that the choke shaft had let go at the linkage arm and would stay closed all the time , bought a new choke shaft and a carb kit and spent $35 , and the float kept sticking and dripping gas , the carb was in a pitted condition internally  , got feed up and bought the after market carb for $46 , been happy with it so far , the OEM carb list for over $200
I am not 100% sure of the year of the tractor , I think it a 72  , the model number is 917.25201
#17 TAHOE ONLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted December 01, 2015 - 08:08 AM
First off, welcome to the forum!!!!
The attachments I got with it are an angle blade , a one sided plow , and the other has 4 adjustable spades and 2 disc wheels , I think it is a row maker , as you can tell I am not a framer ,
You would have a dirt/snow blade, a moldboard plow for plowing gardens, and a cultivator.
you are correct, Sears only made the SS15 in 1972.
#18 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 308 Thanks
  • 241 posts
Posted December 01, 2015 - 08:33 AM
1972 Suburban 15  917.25200     now the last number is not always the same they tend to bounce around between 0 and 1 on these suburban 15. and yes this answers the question grill was replaced. http://www.vintagese...ewsuburban.html
i dont know how my font changed lol
Edited by craftsmanmowerfreak, December 01, 2015 - 08:35 AM.
#19 TAHOE ONLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted December 01, 2015 - 09:05 AM
What's the big tire bike in the back of the second pic?
#20 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 308 Thanks
  • 241 posts
Posted December 01, 2015 - 11:27 AM
heres the regulator http://www.ebay.com/...149a2fe&vxp=mtr like i said theres a extra post on this one doesnt hurt anything i would run the lights off it like on the 71s on back if done right lights will only turn on when ignition switch is on.
belt http://www.autozone..../?checkfit=true
tag on s/g for a 72 suburban 15 (same genertor for many suburbans) 1101689  umm theres some new ones on ebay but are $$$$$ remind you this number is a delco number
and heres a s/g pulley http://www.ebay.com/...L4AAOSwBmZWCcNk
Edited by craftsmanmowerfreak, December 01, 2015 - 11:34 AM.
#21 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 04:23 PM
Thank you so much Craftsman' , I am going to give my guy at the starter shop a call and see if that does anything for him , I am hoping he can build me one ---------the bike in the back round is a classic and I think very rare , we are heavy into ATV's and machines that run in the dirt , I like to fish but my real hobby is  wet dirt , it is a 1973 1/2 Honda Xl250 with a 250 MotorSport engine , last year and they tuned them down  , with an ATV wheel kit on it which I believe was made by Missile Engineering  , it sat in a barn till 3 years ago from 1975
  • 637Yeoman said thank you
#22 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 04:47 PM
I see you put a 16 Briggs in a 15 tractor , i don't know about your motor but on mine you had to remove the front grill to change the oil , so I did some modification to it , drilled and grinded the front grill and added some pipe and a allen headed plug in the end of the 90 degree fitting , makes oil change a snap and no mess , I have not did the second coat of paint on the grill and still have to reinstall the grill screens  and head lights ---also a pic of the stainless tank my buddy made for me
#23 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 308 Thanks
  • 241 posts
Posted December 01, 2015 - 05:16 PM
you have to pull the pan and swap it around
#24 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 06:22 PM
I kinda thought about  rotating the pan , but I didn't want to unbolt the motor , this is more a functionally rebuild and not a restoration and I have a dip stick /filler tube   , had the grill off to work on the carb and choke cable  ,   the oil is easy to change now ----------
I gave the stater guy the numbers and he told me he would get back to me tomorrow -----
knowing the name of my attachments makes me feel like Green Acres , you know that old school TV show , maybe I should go put name tags on them till I get use to them , I moved from New Orleans in 2008 , and live in the rural part , always had nice gardens every year and was the milton king , grows on a vine  some called it coyote pears or coyote squash and there is another name I forget , but man make a stuffing casserole with shrimp and militon and you got it going on
#25 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 06:23 PM
Oh , the rest of that story is , I moved to the North of the lake and can't grow mold !!!
#26 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 308 Thanks
  • 241 posts
Posted December 01, 2015 - 06:30 PM
lol if you decide to pull pan to swap it you will need a gasket umm let me show you a nice site
http://searstractormanuals.com/
this site has alot of manuals even attachments and stuff also theres a engine section in there you will find this specific engine manual
http://searstractorm...iggs_325431.pdf
i take part numbers plug em directly into ebay and boom i find what i need lol
#27 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted December 01, 2015 - 06:41 PM
Nice Honda I like the duals on the sears too bc6e7a6f31d06601f5a09d23afd7b6f2.jpg
Here is my project
[IMG]http://images.tapata...1077d0.jpg[/IMG
Here is my Honda 1971 cl100 I couldn't help but put it on here.
#28 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted December 01, 2015 - 06:42 PM
Here you go
#29 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 01, 2015 - 07:10 PM
Nice site for Roper , got to get the right size tires for the front of my15 it never bother me before but now it does --------I eally like the parts break down in that format , the engine is just a little different than mine , not sure if the dipstick tube was right for my 16 as it has a breath tube nipple on it , I made a vent for it , you might see it in the pics
Nice CL 100 , love the black out look , my neighbor had a gold one , I had a orange and white 1973 Suzuki 125 street and dirt I can't remember the letters, DZ or RZ ,  but I do remember I use to eat his Cl100up ,  I think I would have a gold Fluer de Les (Saints emblem ) on it as even though the Saints ain't worth a darn this year , I still believe ------that is a cool tractor , looks like a Briggs 16 , you could do duals , those are the same rims , it's like $54 for the (I'd call them nylo-tron ) rings  and bolts , the old guy at the lawn mower shop gave me the extra tires
#30 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 308 Thanks
  • 241 posts
Posted December 01, 2015 - 07:16 PM
basic engine parts should be the same like gaskets. from what i see from you model number is front tires should be 16 x 5 x 8
