Honda XL250s
4 replies to this topic
#1 Gtractor OFFLINE
Gtractor
    the homeless tractor hoarder
  • 9,676 Thanks
  • 5,052 posts
Posted November 28, 2015 - 10:25 PM
For some reason when I crack the throttle it makes a terrible popping sound in rapid succession.
Since this pic a few days ago I changed out the sprocket for a much less worn used one.   A new chain and sprockets are in order before warm weather returns.
Edited by Gtractor, November 28, 2015 - 10:32 PM.
  • Alc and Traill95 have said thanks
#2 chieffan OFFLINE
  • 10,962 Thanks
  • 6,946 posts
Posted November 28, 2015 - 10:42 PM
I'd say you got all the goodie out of that sprocket and chain..  They just don't work good when they get that wore down.
  • Gtractor said thank you
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted November 28, 2015 - 11:11 PM
All that grime can wear down metal faster than one would think, some don't understand that clean mechanical parts help stop premature failure. Just an observation, a few minutes of pm can save many hours of frustration later. A wire some water and sand can cut through a marble block in minutes add some diamond and that becomes seconds, I wonder what it would do to steel?
#4 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,548 Thanks
  • 6,199 posts
Posted November 29, 2015 - 08:23 PM
I'd say that sprocket is dead. Original one from the 70s? Lol.
I ordered parts for my klx250s to do over the winter. Going to so some hop up and some maintenance.
#5 olcowhand OFFLINE
  • 42,524 Thanks
  • 31,838 posts
Posted November 30, 2015 - 07:38 AM
I had a KLX250 years ago.  Always wanted either an SL or XL250, but never found one I could afford.
