K181 help
10 replies to this topic
#1 JohnDeere110 OFFLINE
JohnDeere110
  • 210 Thanks
  • 89 posts
Posted November 28, 2015 - 08:41 PM
I went to start my 110 today and the engine was turning over but no ignition. thought maybe I flooded it so I pulled the spark plug out. no gas on it. I then took the air intake off the carb and there was gas dripping out the front of the carb! :wallbanging:  what happened. I need help. :help:
  • 637Yeoman said thank you
#2 637Yeoman OFFLINE
637Yeoman
  • 1,543 Thanks
  • 1,250 posts
Posted November 28, 2015 - 08:44 PM
Flloded it? did you say you had no spark?
  • JohnDeere110 said thank you
#3 JohnDeere110 OFFLINE
JohnDeere110
  • 210 Thanks
  • 89 posts
Posted November 28, 2015 - 08:47 PM
I need a new spark plug but it does still spark
#4 637Yeoman OFFLINE
637Yeoman
  • 1,543 Thanks
  • 1,250 posts
Posted November 28, 2015 - 08:52 PM
I would clean the carb.
#5 chieffan ONLINE
  • 8,403 Thanks
  • 5,818 posts
Posted November 28, 2015 - 09:03 PM
Your plug may show spark out of the head, but does it fire under pressure?  Replace the plug, clean the carb like 637YOMEN said and you will probably be in business.
  • JohnDeere110 and 637Yeoman have said thanks
#6 637Yeoman OFFLINE
637Yeoman
  • 1,543 Thanks
  • 1,250 posts
Posted November 28, 2015 - 10:11 PM
Does it spark nice and blue or is it a yellowish orange.
if it is yellow it probably wont spark under pressure.
It is much harder to have spark under pressure than not.
Good luck, Luke
#7 dodge trucker OFFLINE
dodge trucker
  • 1,885 Thanks
  • 2,503 posts
Posted November 28, 2015 - 11:12 PM
clean and regap the points while you are at it.
#8 Manfjourde OFFLINE
Manfjourde
  • 81 Thanks
  • 180 posts
Posted November 29, 2015 - 03:24 PM
Mine was doing that and it had blue/white spark. I replaced the plug and it fired right up.
#9 JohnDeere110 OFFLINE
JohnDeere110
  • 210 Thanks
  • 89 posts
Posted November 30, 2015 - 03:40 PM
Thanks for the help. I replaced the plug and it started (after a few tries. Now I need to charge the "new" battery from trying to start it so much :hitting_self_roller: )
  • Manfjourde and 637Yeoman have said thanks
#10 637Yeoman OFFLINE
637Yeoman
  • 1,543 Thanks
  • 1,250 posts
Posted November 30, 2015 - 07:49 PM
its amazing what a new spark plug will do.
#11 MiCarl ONLINE
MiCarl
  • 1,656 Thanks
  • 887 posts
Posted November 30, 2015 - 09:28 PM
A plug that has been fuel fouled will often fire outside the engine but not under pressure.  A fuel fouled plug won't necessarily appear wet.
The fuel dripping out of the carb is an indication you have a carburetor problem which can cause the fuel fouled plug.  You should have a look inside the carburetor.  I think you'll find it's dirty or needs a new float needle/valve/float.
