Installing a Dual spool Hyd valve on PK2
4 replies to this topic
#1 MNGB ONLINE
MNGB
  • 1,975 Thanks
  • 1,339 posts
Posted November 25, 2015 - 08:08 PM
Hi all, I wanted to have a second set of hydraulic coupler's on the PK so I could add a hyd cylinder for angling the plow blade or for using my GB Power Grader that has hyd lift vs electric> So I removed the seat and the original flat mount and fabricated a new one with a wider forward end to mount the dual spool valve on then it was to remove the single spool valve and install the dual  valve and connect all the hoses and give it a test try and it works as it should. So Friday its to reinstall the seat etc.HPIM2213.JPG HPIM2214.JPG HPIM2215.JPG HPIM0706.JPG
  • Gtractor, Alc, Ryan313 and 1 other said thanks
#2 Ryan313 OFFLINE
  • 3,365 Thanks
  • 5,230 posts
Posted November 25, 2015 - 08:40 PM
It looks good! I have been wanting to do this, a second cylinder would be nice to have.
  • MNGB said thank you
#3 Bolens QT-17 OFFLINE
Bolens QT-17
  • 122 Thanks
  • 84 posts
Posted November 25, 2015 - 10:08 PM
Nice looking Tractor you got there! :thumbs:
#4 MNGB ONLINE
MNGB
  • 1,975 Thanks
  • 1,339 posts
Posted December 03, 2015 - 06:38 PM
Hi,finished up the dual spool hyd valve and the conversion of the dozer plow blade to hydraulic angling this afternoon, didn't run it out to try but did try it in the shop and is working good.
HPIM2216.JPG HPIM2217.JPG HPIM2218.JPG HPIM2219.JPG HPIM2220.JPG HPIM2221.JPG
  • Alc and 637Yeoman have said thanks
#5 Cat385B ONLINE
    HAZMAT CAT
  • 13,782 Thanks
  • 9,921 posts
Posted December 04, 2015 - 04:09 PM
Paint me green. My Iseki has two spools and I'm still cranking my snowblower chute and manually angling my broom.
It would help if I wasn't so cheap, maybe?
