Posted April 26, 2010 - 02:32 PM
Started pulling this thing apart today.......The throttle shaft on the carb is seized, so its in a bucket of varsol for a few days...hope to loosen it up.....Electrically, it seems good....starter turns the engine, and it has spark, at the coil anyways........spark flying all over, I think the top is cracked, cant see a crack. The engine has compression when I am spinning it with the starter....THe gas tak has a small hole in the bottom......and some rust inside...so, If I can get the carb operational, it should run.
FilledTires said thank you
