We finally made the move to southern Indiana.
185 replies to this topic
#61 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,289 Thanks
  • 1,935 posts
Posted December 07, 2015 - 09:06 AM
  How do the rest of the post look?
There is one post about in the middle of the east outside wall that has about eight inches completely rotted away.
That part of the wall is not sagging though because it is supported by the top header boards and the upper loft in the same way that a bridge span is supported.
The rest of the post on the outside walls look a little rough but are not actually rotted very much.
I'm going to bolt a section of treated 2x6 on each side  each of the outside post and put a piece of 6x6 into the gap on that one outside post.
I think the post on the outside walls may have been bought from a different company then the inside support post.
The inside post are a much darker color then the outside post and the inside post are not rotted at all.
  • wilberj and Jazz have said thanks
#62 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,289 Thanks
  • 1,935 posts
Posted December 08, 2015 - 05:51 PM
Yesterday I got a couple of shots of them connecting the top plate on the walls to the roof of the garage.
Today the ol forklift got to do some work.
They're putting the sheeting on the back wall and we used the forklift for a platform for them to work on.
Here is a shot from the cab of them starting to put the first sheet up on the corner.
The bottom portion of the second panel is being nailed on here.
Later on I got a shot of Don nailing the top of a panel on.
The crane is here to lift the trusses in place and Paul and Dave are making up a "T" bracket to use for lining up the trusses.
Using the forklift again so Don can nail a piece of wood up on the the corner.
Dave has attached the "T" bracket up on the back wall.
They will run a string line between these two pieces of wood for lining up the trusses.
The first truss is lifted off the stack.
Swung up over the walls.
And set in place on the end wall.
The next truss is lifted up.
And set in place.
Here is the last truss going up.
And set in place.
Then they started setting the smaller trusses on the "mud room" between the house and the garage.
  • olcowhand, wilberj, Gtractor and 6 others have said thanks
#63 KennyP ONLINE
  • 41,451 Thanks
  • 47,382 posts
Posted December 08, 2015 - 05:58 PM
It's coming along nicely!
  • jdcrawler said thank you
#64 cglaser104 OFFLINE
cglaser104
  • 4 Thanks
  • 5 posts
Posted December 08, 2015 - 06:28 PM
Awesome progress, its coming along nicely
#65 wvbuzzmaster OFFLINE
  • 4,717 Thanks
Posted December 08, 2015 - 06:30 PM
Looking great there Ray.
#66 olcowhand OFFLINE
  • 43,118 Thanks
  • 31,998 posts
Posted December 08, 2015 - 06:47 PM
Super progress!   :dancingbanana:  It'll be dried in in no time!
#67 UncleWillie ONLINE
  • 16,404 Thanks
  • 9,026 posts
Posted December 08, 2015 - 10:29 PM
Looks great. Where does the railroad track go?
#68 shorty ONLINE
shorty
  • 5,916 Thanks
  • 5,451 posts
Posted December 09, 2015 - 06:50 AM
Looking good. What is the roof pitch, appears to be 7-8. It shouldn't take long to dry it in now.
#69 TAHOE ONLINE
TAHOE
  • 8,336 Thanks
  • 5,818 posts
Posted December 09, 2015 - 08:08 AM
moving along fast!
Uhm, not sure that platform is OSHA approved  :poke:  :poke: :D
Bet those guys love you for it though :thumbs:
A house with no windows   :poke:  :poke:    :rolling:  :rolling:
  • jdcrawler and KennyP have said thanks
#70 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,107 Thanks
  • 6,470 posts
Posted December 09, 2015 - 12:20 PM
I would LOVE a house with no windows.  I hate windows!
  • jdcrawler and TAHOE have said thanks
#71 TAHOE ONLINE
TAHOE
  • 8,336 Thanks
  • 5,818 posts
Posted December 09, 2015 - 12:32 PM
We actually have some neighbors up the road who a few years ago completely closed up all the windows in their house to even removing and putting siding over them and put what looks to be the silver insulation boards on all the doors. I know there are people who are light sensitive, but just seems weird to look at it.
  • jdcrawler, KennyP and toomanytoys84 have said thanks
#72 olds45512 ONLINE
olds45512
  • 1,498 Thanks
  • 739 posts
Posted December 09, 2015 - 04:26 PM
Depending on the laws where your at that might even be illegal or at the very least I'd consider it a real hazard if there was ever a fire.
#73 toomanytoys84 ONLINE
toomanytoys84
    Aaron
  • 11,107 Thanks
  • 6,470 posts
Posted December 09, 2015 - 04:27 PM
Vampires..?
I just dislike light shining in when I don't want it to.  When I worked steady midnight I kept tin foil on my windows.
  • TAHOE said thank you
#74 Jazz OFFLINE
Jazz
  • 2,704 Thanks
  • 1,564 posts
Posted December 09, 2015 - 05:35 PM
There is a family in the 'hood whose children are allergic to sunlight. They have special order windows (amber coloured)to repel 100% UV lights. There was a article in paper a few years ago when they finally got windows..The same tint is also applied on their vehicle windows
Covering up windows with aluminum foil??? Keep a eye on that one!
I want to see the roof on this week!  Looks good.  You are having  really decent weather,  the crews can get lots done,,,
Edited by Jazz, December 09, 2015 - 06:29 PM.
#75 jdcrawler ONLINE
jdcrawler
    tinkerer
  • 4,289 Thanks
  • 1,935 posts
Posted December 09, 2015 - 06:41 PM
Half  of the garage is going to be  walled off with a raised floor and that is going to be my workroom for building trains.
It will be a 8x25 area.
This is a 6-12 pitch roof.
Osha's opinion doesn't matter on things you build and use for your self.
It has sure saved a lot of construction time.
Openings will be cut out and windows will be installed one at a time so the interior stays dry.
  • olcowhand and shorty have said thanks
