High Tunnel Project
24 replies to this topic
#1 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted November 24, 2015 - 07:21 PM
The high tunnel finally arrived today! it was suppose to be here last week but the delivery truck kept putting it off. It got here just in time for the high winds and rain!.
This high tunnel is 30' wide and 70' long, this is going to look really impressive when we get it up. We got the upgraded metal base and hip boards which are going to be really nice.
Our neighbor/employer brought out his 120hp John Deere with post hole digger and we got 30 holes drilled in a little over a hour. We will half to dig out some of the holes by hand because we hit some pretty decent rock. We broke the sheer bolt twice trying to get through some of the rock. Hoping to start getting post set tomorrow, then we have a 100% chance of rain on Thursday then 60% chance a few days after that. Hoping to get as many post set before the holes fill full of dirt and water.
I will try to keep this updated when ever we get work done on it, the weather says it's going to clear up next week with no rain or wind. The past 3 weeks we have had 20 to 30 mph winds and I'm starting to get sick of it.
Sorry for the lousy pictures, it was getting dark when I was taking them.
Edited by BTS, November 24, 2015 - 07:25 PM.
  • olcowhand, Gtractor, MH81 and 8 others have said thanks
#2 KennyP ONLINE
  • 40,044 Thanks
  • 46,732 posts
Posted November 24, 2015 - 07:27 PM
Sounds like good GT parking space to me!
  • boyscout862, BTS and propane1 have said thanks
#3 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted November 24, 2015 - 07:29 PM
Make the GT's healthier being in the sun!
  • KennyP, boyscout862 and propane1 have said thanks
#4 chieffan OFFLINE
  • 10,885 Thanks
  • 6,916 posts
Posted November 24, 2015 - 08:15 PM
Sun fades them and the rest of the weather destroys them.
  • KennyP, boyscout862 and BTS have said thanks
#5 MH81 OFFLINE
Posted November 24, 2015 - 08:26 PM
Looks like it will be a nice grow area.
Good luck and be safe
  • boyscout862 and BTS have said thanks
#6 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted November 25, 2015 - 12:39 AM
We are going to have a fun time reworking the ground after running all the machinery over it!, next we are going to be driving our dump truck all around on it while putting up hoops. I guess I'm going to go at it with our little ripper and go from there.
#7 Alc OFFLINE
  • 7,115 Thanks
  • 7,529 posts
Posted November 25, 2015 - 07:30 AM
I've read a little about hoop houses but I'm sure I'll be getting better info from you as you give real life stories about using it , Both good and bad ,what works and changes as you use it
#8 boyscout862 OFFLINE
  • 13,431 Thanks
  • 9,380 posts
Posted November 25, 2015 - 08:44 AM
Looks like a great project. One thing I worry about with light structures is wind. Becarefull to anchor things down while you are erecting it. The wind has impressed me many times. Be carefull with the wind. Good Luck, Rick
  • BTS said thank you
#9 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted November 25, 2015 - 09:42 AM
This high tunnel will have 30 legs, all of them will be in the ground 32", we are setting all of the legs in post set (fly ash) and we are also going to drill a hole in the bottom of each leg and put a piece of rebar across so the legs will have a harder time pulling out. The metal base & hip boards will hold all the post to each other, with any luck all of this will hold it in. We have a 12' X 25' greenhouse made out of PVC pipe and it has held up great.
#10 Bolens QT-17 OFFLINE
Bolens QT-17
  • 122 Thanks
  • 84 posts
Posted November 25, 2015 - 03:09 PM
Good luck on your project!
#11 toomanytoys84 OFFLINE
toomanytoys84
    Aaron
  • 10,490 Thanks
  • 6,178 posts
Posted November 25, 2015 - 03:33 PM
Sure glad you didn't have to hand dig all those holes.  Wow.  Post hole digging is one job that I despise....
I rented a 2 man gas auger one time.  Only had myself to run it.  Even though that was tough in itself, it was still better than manually digging 28 holes to put up my fence at my old house.
#12 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted November 27, 2015 - 09:36 AM
Got 2 inches of rain yesterday, it turned into ice overnight and now today suppose to sleet. Not going to get anything done till middle of next week probably. :(
#13 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted November 28, 2015 - 10:20 PM
The high tunnel is off to a bad start, we have gotten around a 1/4inch of ice so far, it misted all day today, it's now raining again now and it's 28 degrees. :(
It's suppose to rain all day tomorrow and Monday :wallbanging:. After that the temps are suppose to rise and the wind is going to blow around 20mps, I guess we will see how things dry up, we are hopping to start setting post on Tuesday, but that all depends on how fast things dry up, most likely we wont be able to do anything till Thursday :wallbanging:
#14 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted December 08, 2015 - 10:30 PM
Finally, it's now dry enough to get some work done, we got the high tunnel unloaded off the trailer today. We got the holes cleaned out a couple days ago, today we also got 6 post set in, we are putting fly ash (post set) in the holes to keep them in a little better. Hoping to get the rest of the post in tomorrow and we will see what's next after that.
  • olcowhand, Alc, wvbuzzmaster and 1 other said thanks
#15 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,531 Thanks
  • 2,555 posts
Posted December 11, 2015 - 10:35 AM
Yesterday we finished setting the post on one side, hoping to get the other side done today.
Also put together one hoop just to see what it looks like, can't wait to start putting them up!
