Crankshaft straightening
8 replies to this topic
#1 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 24, 2015 - 03:58 PM
  Tried this as I read about it being done a couple of yrs ago. Sorry, no pics so I guess It didn't really happen. Drained oil, set it upside down on some milk crates(boy those are handy) and strapped it down to them. Removed blade and hub, slipped a piece of 1" pipe over the shaft and whacked w/ the 8 pounder until I couldn't see the runout . tacked a piece of flatbar to the deck for the  dial indicator's magnetic base to stick on and worked on it w/ pipe and 2 pounder until I got it down to about .008" runout. Reassembled, filled w/ oil and fired it up. Seems as smooth as any other push mover I've had. Sitting running in the yard now to see if crankshaft is going to break. What surprised me was the crank had about 1/4" of runout but it didn't bend the blade.
                                        Mike
  • Gtractor, Alc, Lmiller3358 and 2 others have said thanks
#2 boyscout862 ONLINE
  • 12,843 Thanks
  • 9,169 posts
Posted November 24, 2015 - 04:28 PM
Great backyard mechanicing. I picked up one of the professional straighteners at a tag sale 15 years ago. It is very precise but I'm not sure its worth it. They sell for big bucks at some of the dealers. Sounds like you have the cheap solution. Good Luck, Rick
  • Lmiller3358 and propane1 have said thanks
#3 Lmiller3358 ONLINE
Lmiller3358
  • 1,480 Thanks
  • 1,421 posts
Posted November 24, 2015 - 06:25 PM
Nothing like a little persuasion !
#4 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,915 Thanks
  • 2,451 posts
Posted November 24, 2015 - 06:44 PM
I have found that the worse the crankshafts are bent, the easier they are to straighten.
Of course, this applies to the longer crankshafts.
#5 Bmerf OFFLINE
Bmerf
  • 1,796 Thanks
  • 1,466 posts
Posted November 24, 2015 - 07:00 PM
Did it blow up?
#6 dthomp17 OFFLINE
dthomp17
  • 587 Thanks
  • 472 posts
Posted November 24, 2015 - 07:25 PM
From your description, I'm assuming the crankshaft was not removed from the engine before straightening. How did you manage to not damage the crank bearings or cracking the engine crankcase while pounding with the 8 pounder?
#7 chieffan OFFLINE
  • 10,132 Thanks
  • 6,632 posts
Posted November 24, 2015 - 08:10 PM
Nothing like instant impact.  My Uncle, a German immigrant blacksmith had a saying;  "If it ain't broke, get a bigger hammer"
#8 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 24, 2015 - 10:10 PM
Did it blow up?
  Nope, it ran for about 45 min full speed until it ran out of gas. No evidence of cracks or oil leaks.
                                                 Mike
  • limebuzz said thank you
#9 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
  Luck, I guess.
                         Mike
