How do you Replace Bearings and Seals on Peerless Transaxles?
peerless steiner 420 s20 steiner
5 replies to this topic
#1 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted November 24, 2015 - 02:06 PM
I replaced the hydraulic oil in my S20 last night. I jacked it into the air to get an oil pan under it, and noticed the right front tire and wheel slopped down... I checked it and it moves in 4 axes about 1/8 inch...
I suspect a worn bushing or bearing in it...but can't find any information on how to repair them... I'm sure you have to remove the axle extension, but do you have to tear the tranny apart as well???  Any help would be appreciated.
Smitty
#2 boyscout862 ONLINE
  • 12,521 Thanks
  • 9,031 posts
Posted November 24, 2015 - 03:56 PM
Smitty, Have you checked our transmission manuals section?  This one is pretty good for most of them.  http://gardentractor...chanics-manual/   There are more too. Good Luck, Rick
#3 glgrumpy ONLINE
  • 8,549 Thanks
  • 7,877 posts
Posted November 24, 2015 - 05:23 PM
Front wheel you say moves, but have to tear into trans?  What is this S-20?  Confused on that. You meant rear wheel? Seals should come out with work would think from outside, but bearings probly need complete tear-down. If not leaking yet, I would wait, but that is Me!
#4 shorty ONLINE
shorty
  • 5,276 Thanks
  • 5,162 posts
Posted November 24, 2015 - 05:35 PM
Is it on the Steiner?
#5 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted November 25, 2015 - 12:19 AM
Sorry, I should have been more specific.  The S20 is a Steiner articulated tractor--the model that precedes the 420, and essentially the same tractor in the early version.
It has a Peerless 2502 transaxle... same basic unit as the Ford LGT Hydros used, also the old MTDs, etc.
Smitty
#6 Utah Smitty OFFLINE
Utah Smitty
  • 1,701 Thanks
  • 1,781 posts
Posted November 25, 2015 - 12:21 AM
Yes... Sorry, I should have been more specific. It is the same basic transaxle as the ones on the early MTDs, and the Ford hydro LGTs...
The Ford LGT parts manual shows a seal and a bearing on the end, but this has so much slop it makes me think it's a bushing, but my Steiner parts manual doesn't say--it just has the whole transaxle.
Smitty
Also tagged with one or more of these keywords: peerless, steiner 420, s20, steiner
