Bolens Iseki Diesel G154 Snowblower repair.
bolens iseki g154 g174 snowblower 1948 diesel
34 replies to this topic
#31 darkexphos OFFLINE
darkexphos
  • 26 Thanks
  • 30 posts
Posted August 08, 2016 - 08:31 PM
Apologies on the thread rez, but I had this bookmarked and I was working on my own model 1949 blower today.  I thought I had a bad motor, but testing determined it was a wiring problem.  At any rate, before I got it figured out, I spent some time trying to figure out what the motor is from.  I'm 98% sure that it's a window motor that fit a pile of 70s/80s GM vehicles, including some Suburbans as a tailgate actuator.  I happened to track the picture down on Rock Auto, but many other sources will work.  Look at the front left/right rear window actuator for a '76 Oldsmobile Custom Cruiser.  Cardone P/N 82016 or 4216.  The gear is listed as well, Cardone P/N 8290 or 4290.
Thanks for the info. Pretty soon ill have to get working on this project again. It got put on the backburner for the summer
#32 darkexphos OFFLINE
darkexphos
  • 26 Thanks
  • 30 posts
Posted December 15, 2016 - 01:43 PM
Hey everyone I've finally gotten back to the project. I still haven't gotten around to getting the electrical hooked up however I have gotten the blower mounted and Hydraulics plumbed. I was able to repair the aux hydraulic valve so it no longer leaks. I also replaced all but the 2 long hoses that run to the front. Here's some pics. Today I'm going to pick up some steel to make a basic cab as it gets insanely cold here in Wisconsin. More updates to come
#33 mjes92 OFFLINE
mjes92
  • 39 Thanks
  • 36 posts
Posted December 15, 2016 - 02:22 PM
I see you bypassed the engine manifold and went direct to two mufflers.  Any benefit to that?
You will need a good 350+ lbs hanging on the 3pt to effectively push that beast around on a heavy snow day.
My set up below.  Hydraulically actuated.  The blower is 500 lbs.  Hence the need for counter weights.
You'll have a lot of fun.
  • Bolens 1000, ClassicBolens, Leonard VanCamp and 1 other said thanks
#34 ClassicBolens OFFLINE
ClassicBolens
  • 1527 Thanks
  • 516 posts
Posted December 15, 2016 - 03:58 PM
Very nice mjes92. Don't see too many of the 51" 2 stage blowers.
#35 darkexphos OFFLINE
darkexphos
  • 26 Thanks
  • 30 posts
Posted February 28, 2017 - 06:22 PM
I don't think there's any real benefit to bypassing the manifold. The reason I did it was my muffler was long rusted away when I got the tractor so I took the 2 flanges that were left and welded 2 90s to them and stuck those small tractor mufflers on as I couldn't find a reasonably priced original muffler.
Also tagged with one or more of these keywords: bolens, iseki, g154, g174, snowblower, 1948, diesel
