Plow question
5 replies to this topic
#1 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted November 23, 2015 - 11:10 PM
Which is easier to pull one 14" bottom or two 10" bottoms both going 5" depth? Wondering if it would be easier to pull a 14 because it is 6 less inches or if it is easier to pull the two 10" because each bottom is moving less dirt
  • propane1 said thank you
#2 olds45512 OFFLINE
olds45512
  • 1,338 Thanks
  • 677 posts
Posted November 23, 2015 - 11:20 PM
the 14" should be easier to pull but depending on the tractor it might pull the 2 bottom just fine.
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,469 Thanks
  • 1,106 posts
Posted November 24, 2015 - 09:32 AM
The 14" would be eaiser to pull
#4 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted November 24, 2015 - 11:36 AM
The 14" may not plow right at 5". It should be at 7" deep. No difference just in a garden, but if you are in a plow match, the 14" should be at 7" deep. Noel
Did some figuring and the 14" wide plow x 7" deep = 98 sq in, in the ground you have to pull. The two 10" wide plows x 5" deep = 100 sq in. So that's about the same amount of pull. The 14" plow 5" deep = 70 sq in.
So the 14x5 should be easier to pull than the two 10x5's. Just my guess, Noel.
Edited by propane1, November 24, 2015 - 11:49 AM.
#5 1964Deere OFFLINE
1964Deere
  • 249 Thanks
  • 292 posts
Posted November 24, 2015 - 12:53 PM
My thought was with a GT I'd need to plow at 5" to stay in line with 10" plows. Also wondering if at plow day if a 10" plow would be able to cover my 14" furrow?
#6 propane1 ONLINE
propane1
  • 8,480 Thanks
  • 4,040 posts
Posted November 24, 2015 - 01:02 PM
I think one sod would be higher than the other, same with width, one wider than the other.  Noel
