well i dont think i mentioned the custom 8e on this site yet lol
12 replies to this topic
#1 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 318 Thanks
  • 246 posts
Posted November 23, 2015 - 03:35 PM
  • Gtractor, MH81, Traill95 and 1 other said thanks
#2 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted November 23, 2015 - 04:24 PM
Nice tractors, my dad was given a wheel horse charger 10 with a mower deck for free I'm tearing it down and replacing all the engine gaskets and painting it up real nice.
  • craftsmanmowerfreak said thank you
#3 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6771 Thanks
  • 4562 posts
Posted November 23, 2015 - 05:11 PM
Whats the paint code on the cans that you used on the SS14?  That's really close to the original color.I keep looking at paint and every one I've looked at was to Blue or to Green.
#4 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 318 Thanks
  • 246 posts
Posted November 23, 2015 - 05:15 PM
verde green by rustolium. rooney from youtube uses it
  • MH81 and EricFromPa have said thanks
#5 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 318 Thanks
  • 246 posts
Posted November 23, 2015 - 05:27 PM
its not exact but close enough.
#6 EricFromPa OFFLINE
EricFromPa
  • 6771 Thanks
  • 4562 posts
Posted November 23, 2015 - 05:34 PM
Rustoleum 7219-830 Verde Green
Spray paint. Unique hammered finish. No primer needed. Hides surface imperfections. Apply directly over rust.
lol Just what i need something that will cover rust.I'll end up sanding and priming all of the big parts so rust doesn't bleed through.I might even wet sand and use a nice Crystal clear coat paint over it.I got a couple cans of Krylon Crystal Clear the other day to fix the trunk lid on the car.It turned out really good.I'll have to try a couple test spots once I get paint for my SS14.
Had to warm up the trunk lid a bit 1st then put a tac coat and let it set a few minutes then I hit it with 2 pretty heavy coats.Didn't have to do any finish work to it.It leveled out and looks like glass.I think the trick to a good clear coat is a nice warm surface.
Edited by EricFromPa, November 23, 2015 - 05:41 PM.
#7 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted November 23, 2015 - 05:42 PM
Where die you get your wheel weights?
#8 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted November 23, 2015 - 05:43 PM
* did* not die sorry
#9 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 318 Thanks
  • 246 posts
Posted November 23, 2015 - 05:46 PM
ok i sand down all my peices that i paint and use the brown rustoliem primer before i paint. lol i do light coats of paint. its a little greener than original paint but ohh well its very close
ok one set i got when i picked up  sears custom out of a scrapyard. other set out of a mower junkyard. 132 lbs total.
Edited by craftsmanmowerfreak, November 23, 2015 - 05:47 PM.
#10 warrior120 OFFLINE
warrior120
  • 56 Thanks
  • 74 posts
Posted November 23, 2015 - 05:58 PM
OK thanks
#11 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 318 Thanks
  • 246 posts
Posted November 23, 2015 - 06:03 PM
OK thanks
each sears weight weights 33 lbs.
#12 Rocko OFFLINE
Rocko
  • 25 Thanks
  • 44 posts
Posted December 04, 2015 - 08:02 AM
Nice video CMF , I like the bearing splitter idea on the steering wheel , not real happy with my wheel and have a few others laying around ----do you know what size the shaft is ,  is it key wayed , tapered , both , ???  ------------ do you sell parts , I could use a belt guard ? do you know what motors all use the same guard ????
#13 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 318 Thanks
  • 246 posts
Posted December 06, 2015 - 08:56 PM
i got no parts for sale well atleast for one of these lol. umm shaft is a 3/4 inch and uses a woodruff key its a straight shaft.
