Most people put rubber on there impeller paddles, I put
No replies to this topic
#1 propane1 ONLINE
  • 8,976 Thanks
  • 4,225 posts
Posted November 23, 2015 - 12:47 PM
Metal ones on. Had no rubber, and was easier to cut some metal and weld them on. Test fitted, then welded. May not be as close as rubber, but the metal ones are on. I also am not realy convinced that they work as good as said on all the you tube videos. I figured, what the heck, I'll try it. If it throws better, that's good, if not, oh well. Noel.
  • Alc, Bruce Dorsi, hamman and 1 other said thanks
