Key way in shaft a little loose, so
8 replies to this topic
#1 propane1 ONLINE
propane1
  • 8,715 Thanks
  • 4,124 posts
Posted November 23, 2015 - 11:25 AM
I cut a new one with my rotary tool. Then welded in the old key way, put the cog on. Then broke the bolt off to help hold the cog on, "(&"$)&@")), welded a nub on the bolt, didn't work, then tried an easy out, didn't work, drilled it and tapped it, put 5/16 bolt in. So that finally got fixed. Now on to the next trouble, I'm going to make. Noel
  • olcowhand, Gtractor, MH81 and 6 others have said thanks
#2 KennyP ONLINE
  • 38,242 Thanks
  • 45,869 posts
Posted November 23, 2015 - 12:03 PM
I'm glad you got it all back together! Sounds like some of my days!
  • boyscout862 and propane1 have said thanks
#3 olcowhand ONLINE
  • 41,056 Thanks
  • 31,392 posts
Posted November 23, 2015 - 12:18 PM
Looks like a good repair!  :thumbs:  As far as the extra trouble with the broken bolt....we can all usually count on things like that.
  • boyscout862, HANKG and propane1 have said thanks
#4 MH81 OFFLINE
Posted November 23, 2015 - 12:25 PM
No good deed or intentions go unpunished... :D
#5 chieffan ONLINE
  • 10,105 Thanks
  • 6,621 posts
Posted November 23, 2015 - 01:53 PM
Just when we think things are going our direction, something turns the road sign.
When you encounter a twisted off stud like that, weld a nut onto the stub good and solid.  Let it cool down then heat the area on one side of the part where the stud is in and turn the stud out.  Heat it fast and only one side so you don't heat the stud up also.  Learned this from a guy who ran a welding and repair shop.
  • propane1 said thank you
#6 glgrumpy OFFLINE
  • 8,605 Thanks
  • 7,909 posts
Posted November 23, 2015 - 03:42 PM
I would have to walk away from that after bolt snap, think on it awhile, then maybe come back another day to try again. I have very few times that I can keep the drilled hole centered, do don't like to do that. Must have steady hand to grind a key with dremel, mine would be all wallowed out, same as the damaged, heh!  What is this on? Not a GT.  This at your work?  Not just a shaft they could have replaced?
  • MH81 and propane1 have said thanks
#7 propane1 ONLINE
propane1
  • 8,715 Thanks
  • 4,124 posts
Posted November 23, 2015 - 04:46 PM
Snowblower for the lgt145 ford. Shaft replacement is nasty. Easier to get new shaft and make an impeller, like I did last year to the other blower, than to put a new shaft in old impeller. Noel.
#8 HANKG ONLINE
HANKG
  • 6,298 Thanks
  • 3,419 posts
Posted November 23, 2015 - 08:13 PM
Just wondering could you have welded the key in the wallowed area ?
#9 propane1 ONLINE
propane1
  • 8,715 Thanks
  • 4,124 posts
Posted November 23, 2015 - 10:01 PM
Would not be able to get the bearing off for replacement then. Noel
  • Alc and HANKG have said thanks
