what year was this Bolens made
6 replies to this topic
#1 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted November 23, 2015 - 08:39 AM
hello all, does anyone have a serial number / year comparison sheet , I have a bolens ridemaster type 35AB03 serial number R4601, I was told it was a possibly 1951, it has the wisconson motor on it so I am assuming it is before 1954, all I have been able to find out is that it could be 1947 - 1953, any info helps thanks john
#2 Bolens 1000 OFFLINE
  • 14,987 Thanks
  • 18,140 posts
Posted November 23, 2015 - 08:40 AM
Member wilberj should be able to tell you, do you have the engine numbers?
  • farmer john said thank you
#3 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted November 23, 2015 - 09:10 AM
this is what I can see on the motor, top line   AKN       2282696   second line  2 7/8 X 2 3/4    63578
#4 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted November 23, 2015 - 09:23 AM
thanks for the tip on the motor numbers assuming that 2282696 is the serial number it was built mid 1953, and all references I have seen call for a brigs in 1954 I think it is safe to assume my ridemaster is a 53. however I have been wrong before ( don't tell my wife I admitted that , i'll deny ever saying it ha ha ha!!!)
Edited by farmer john, November 23, 2015 - 01:56 PM.
#5 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted November 23, 2015 - 10:47 PM
You shore those are the modal and serial of the tractor?
Also the engine serial number must not be right.
#6 farmer john OFFLINE
farmer john
  • 1,782 Thanks
  • 906 posts
Posted November 24, 2015 - 08:10 AM
my mistake serial number on tractor R 6401 all other numbers are correct
#7 wilberj ONLINE
wilberj
  • 5,003 Thanks
  • 5,595 posts
Posted November 24, 2015 - 10:28 PM
That sounds better! 4601 is to low of a number to be a 35AB03 that's why I asked.
The engine is a 1954 that makes the tractor a 1954.
Also Bolens ridemasters started in 1948.
Edited by wilberj, November 24, 2015 - 10:29 PM.
