adaptable ignition system tecumseh
7 replies to this topic
#1 cyril.lg56 OFFLINE
cyril.lg56
  • 53 Thanks
  • 16 posts
Posted November 22, 2015 - 03:15 PM
Hi everybody!
Like a lot of people, I have a colleague who has a MF10 with hh100 tecumseh engine, the coil is breaking and saw the price of this coil, it can not be put out with the tractor engine!
I thought prolongation pence and I have a solution, use an external motor coil, and for the callage of ignition, pose Electronic ignition module! Current supply devices for in the coil, the original alternator can be reused!
the idea in his works, but I need your expert opinion, do you think can this tendering system work? and if someone is already doing!
  • Traill95 and boyscout862 have said thanks
#2 jms180 ONLINE
jms180
  • 1,480 Thanks
  • 1,549 posts
Posted November 22, 2015 - 04:57 PM
http://gardentractor...s.com/index.htm
Check this site for more info
Edited by jms180, November 22, 2015 - 08:51 PM.
#3 boyscout862 OFFLINE
  • 12,551 Thanks
  • 9,044 posts
Posted November 22, 2015 - 05:35 PM
Check this site too. http://home.earthlin...ller/index.html Good Luck, Rick
  • Alc, jms180 and Traill95 have said thanks
#4 Tecumseh power ONLINE
Tecumseh power
  • 1,468 Thanks
  • 1,106 posts
Posted November 22, 2015 - 08:17 PM
I've done it but I used a different trigger coil
#5 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted November 23, 2015 - 07:56 AM
Check the Tecumseh SSI link in my sig for some of the different coil applications.
Most need some type of control module to control signal, mine uses a single trigger to break coil field to fire.
I am not sure what your little silver box is or what you plan to use as a trigger off the flywheel.
Edited by TAHOE, November 23, 2015 - 07:57 AM.
#6 cyril.lg56 OFFLINE
cyril.lg56
  • 53 Thanks
  • 16 posts
Posted November 23, 2015 - 01:55 PM
Hi everybody!
the shutter (we call home switch and capacitor) that can replace an ignition module, it is very common on the old machine is reliable and good price!
basically, if wanted I change my ignition system to put in a different parralèles! I reuses the stator
According to you, does it work?
(grieve for my spelling, I use a translator because I'm french)
#7 jms180 ONLINE
jms180
  • 1,480 Thanks
  • 1,549 posts
Posted November 23, 2015 - 02:23 PM
I have seen the module used like this to do away with points. If you are using an external coil you need a trigger signal at TDC as Tahoe mentioned in his post.
Edited by jms180, November 23, 2015 - 02:28 PM.
#8 TAHOE OFFLINE
TAHOE
  • 7,814 Thanks
  • 5,612 posts
Posted November 23, 2015 - 03:17 PM
Hi everybody!
I am not familiar with your shutter so can't help you there.
The stator can still be used, but it will charge the battery and the coil will feed from the battery. I run my coil through a toggle switch and that is how I turn the ignition on/off to shut down engine.
My Tecumseh is set at about 25*. A little harder to start, but runs good at wide open throttle.
  • limebuzz said thank you
