Safety switch adjustment
13 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted November 22, 2015 - 01:29 PM
Is there a way to adjust the PTO safety switch that's located under the steering column? Sometimes I have to pull down on the PTO lever to make it start.
Thanks
#2 chieffan ONLINE
  • 11,412 Thanks
  • 7,139 posts
Posted November 22, 2015 - 01:43 PM
What tractor?
  • Eric said thank you
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted November 22, 2015 - 01:44 PM
I am figuring its a JD but the model may help someone to answer your question.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 14,379 Thanks
  • 10,146 posts
Posted November 22, 2015 - 04:13 PM
JD 214, I believe.
#5 lyall ONLINE
lyall
  • 2,228 Thanks
  • 1,594 posts
Posted November 22, 2015 - 08:14 PM
Yes you can adjust the PTO safety switch.
The PTO safety switch bolts to has two slots the you can adjust the switch.
Loosen one or both bolts then you can make the adjustments.
Also the neutral safety switch is adjustable too.
#6 glgrumpy ONLINE
  • 8,816 Thanks
  • 8,014 posts
Posted November 22, 2015 - 08:23 PM
I bet a good lubing with WD40 or similar would be helpful. Might just be full of dust and such.
#7 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted November 27, 2015 - 10:06 PM
Yes it's a 214. I will try the WD40 and loosening the adjustment bolts. Thanks for replying
#8 dodge trucker ONLINE
dodge trucker
  • 2,827 Thanks
  • 3,460 posts
Posted November 27, 2015 - 10:13 PM
I like to "adjust" their position, right into the round file... not gonna say "how" (it varies by machine a bit anyways)
#9 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 13, 2015 - 09:05 AM
Are the 2 bolts in this pic where u adjust the PTO safety switch, or can u not see them from this angle?
Anyone know the part # for this pto switch in case I can't adjust it?
Thanks
Edited by coinman66, December 13, 2015 - 09:40 AM.
#10 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 13, 2015 - 12:08 PM
UPDATE:
I loosened the 2 nuts circled and move plate up\forward and it seemed to have fixed my problem.
#11 lyall ONLINE
lyall
  • 2,228 Thanks
  • 1,594 posts
Posted December 13, 2015 - 02:45 PM
coinman66
wrong two bolts
you adjust the two little bolts below in the picture.  if you were to take the safety switch off you will see that there are two slots the the little bolts.
just loosen one or both of the little bolts to make the adjustment.
there is another safety switch down by the shifter.
  • coinman66 said thank you
#12 coinman66 OFFLINE
coinman66
  • 182 Thanks
  • 296 posts
Posted December 13, 2015 - 04:20 PM
coinman66
wrong two bolts
UT oh lol. It starts now without me pulling down on PTO lever, but u know I never did see if PTO engages blades ok? Thanks for the info and back out to the garage later for me. I will let u know how it goes.
Thanks!
#13 pidjones OFFLINE
pidjones
  • 58 Thanks
  • 51 posts
Posted January 07, 2016 - 03:09 PM
I think my 216 has two switches stacked there - one for starting circuit, the other for ignition if you leave the seat with PTO engaged.
#14 lyall ONLINE
lyall
  • 2,228 Thanks
  • 1,594 posts
Posted January 07, 2016 - 05:17 PM
yes pidjones
one side of the PTO switch goes to seat switch (pink wires)
the other side of the PTO switch goes tho the ignition (coil)
here is a diagram for the wiring
