2 Stage Snowblower Rebuild Restoration
ford lgt jacobsen gt 2 stage
8 replies to this topic
#1 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 20, 2015 - 07:42 PM
Should blow alright this winter i think!
  • hamman, JDBrian, Traill95 and 1 other said thanks
#2 Bolens 1000 OFFLINE
  • 14,903 Thanks
  • 18,103 posts
Posted November 20, 2015 - 07:44 PM
Nothing throws snow like a freshly painted blower!
#3 fxdb96 OFFLINE
fxdb96
  • 118 Thanks
  • 105 posts
Posted November 20, 2015 - 07:49 PM
Especially with the chute being "Canadian Chromed".  Chrome in a can lays on thick and smooth!  Hopefully it is durable enough to handle a few rocks - i did prep well and self etch prime so we shall see.
#4 propane1 ONLINE
propane1
  • 8,465 Thanks
  • 4,036 posts
Posted November 20, 2015 - 08:22 PM
I am doing a modification to one of mine. I cut out some of the impeller paddles to allow for more vacuum in the centre of the impeller to allow more snow to be sucked in and throwen out. I made a new one for my other blower last year, and put five paddles on it instead of four. The other thing I do through the season , is to spray the blowers with tremclad clear gloss paint. Helps keep them slippery so snow gets out better. Last picture is of the one I made, blue is the new one , compared to the old one. Noel
  • JDBrian, chris m, boyscout862 and 1 other said thanks
#5 Eric OFFLINE
Eric
  • 1,322 Thanks
  • 813 posts
Posted November 20, 2015 - 10:40 PM
So you tried this last winter? How did it compare to the non modified impeller?
  • boyscout862 and propane1 have said thanks
#6 propane1 ONLINE
propane1
  • 8,465 Thanks
  • 4,036 posts
Posted November 21, 2015 - 04:26 AM
Works better, throws a bit farther, seems to be able to run the tractor at a little faster ground speed. The most noticeable is that it throws the same distance in any direction, where as before it would throw better to the right than left. Noel
I read some where, that the more paddles on the impeller, the less hp it takes to run it. Gearing helps a lot also. I played with the ratios between the cog at the impeller and the drive source, which slowed down the impeller, but threw just as far. The way is was, is the engine would slow down and you would have to slow up the tractor or stop to let the engine rev back up. The ratio change in the cogs stopped that. Now the tractor travels at what ever speed for the conditions, engine speed stays constant. Big difference in tractor engine performance and less gas to operate.
I did the ratio change a few years ago, the new impeller was last year. I am hoping for some improvement on the blower that I am working on now. It's my sons.
Edited by propane1, November 21, 2015 - 04:54 AM.
  • Alc, KennyP and Eric have said thanks
#7 Eric OFFLINE
Eric
  • 1,322 Thanks
  • 813 posts
Posted November 21, 2015 - 06:09 AM
Shoot me a pm when you test your improvements I would love to know what combination of impeller blades and gearing is the most successful. Looks like your well on your way to becoming the snowblower afficianado, good work! Thanks for sharing the Intel, always nice to have someone willing to go the extra mile and share their work with us plebes. Eric.
  • JDBrian and propane1 have said thanks
#8 JDBrian OFFLINE
  • 9,606 Thanks
  • 14,142 posts
Posted November 21, 2015 - 07:47 AM
After last winters record snow fall Noel is well on his way to a masters degree in snow blowing. Nice work on the snow blower mods Noel.
  • KennyP and propane1 have said thanks
#9 KennyP ONLINE
  • 37,451 Thanks
  • 45,477 posts
Posted November 21, 2015 - 08:22 AM
Glad the things you are doing show an improvement!
