starter generator question
6 replies to this topic
#1 dodge trucker ONLINE
dodge trucker
  • 1,795 Thanks
  • 2,368 posts
Posted November 18, 2015 - 11:05 PM
I have 2 starter generators here on the garage shelf that I had forgotten about. I discovered them when pulling my 12' long shelving unit out from the wall to do some insulating/drywall work behind it, had to clear it off to be able to pull it out from the wall.
I have a CC 129 and my son has a CC Original here that also have s/g's on them. I know that CC's (Cub Cadets) have starter/gens that run opposite rotation of other brands because they hook up to the PTO end of the crank instead of the flywheel.
On both units that I have on the shelf, the ID tag is still intact and still legible on at least one.
IS there a cross reference chart somewhere that tells specs on these units? (amp output as a gen, amp draw as a starter, and most importanttly, intended rotation?
Edited by dodge trucker, November 18, 2015 - 11:06 PM.
  • chieffan said thank you
#2 Oldford OFFLINE
Oldford
  • 1,015 Thanks
  • 713 posts
Posted November 19, 2015 - 04:46 PM
Maybe you could bolt it down and hit it with 12 volts, see which way it spins...?  Is it ok to hit it with reverse polarity, would it run backwards or just burn up?
#3 MH81 ONLINE
  • 29,510 Thanks
  • 29,568 posts
Posted November 20, 2015 - 08:07 AM
Whichever the rotation, it should be negative ground. Secure it, Hit it with power, and tag it for the next time you find it.
#4 dodge trucker ONLINE
dodge trucker
  • 1,795 Thanks
  • 2,368 posts
Posted November 20, 2015 - 01:06 PM
#5 dodge trucker ONLINE
dodge trucker
  • 1,795 Thanks
  • 2,368 posts
Posted November 20, 2015 - 01:08 PM
Which terminal gets the "hot" for this test, the F or the A terminal? It's been too long since I have messed with one.
#6 MH81 ONLINE
  • 29,510 Thanks
  • 29,568 posts
Posted November 20, 2015 - 04:10 PM
Honest to Pete, I am going to have to look.
I think it's A, but not sure.
#7 Bruce Dorsi OFFLINE
Bruce Dorsi
    Old, but not dead -- yet!
  • 3,765 Thanks
  • 2,387 posts
Posted November 20, 2015 - 05:51 PM
Definitely the "A"  (Armature) terminal !
