Bearing question
4 replies to this topic
#1 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted November 18, 2015 - 08:56 PM
I ordered a bearing off ebay thinking it was part number IH ST-436 which I need for my K301. But the bearing I got is in a box that has ST 436 then below that says BB C 340. The bearing itself says C340. What is the bearing I actually received for? [attachment=175944:ImageUploadedByTapatalk1447898015.566818.jpg][attachment=175945:ImageUploadedByTapatalk1447898043.135142.jpg][attachment=175946:ImageUploadedByTapatalk1447898064.902025.jpg][attachment=175947:ImageUploadedByTapatalk1447898138.717369.jpg]
#2 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted November 18, 2015 - 08:59 PM
Did you measure it to see if it is the same size as the one you need , sometimes part numbers change and they will write the new or old one on it
  • dlang94 said thank you
#3 Tecumseh power OFFLINE
Tecumseh power
  • 1,479 Thanks
  • 1,115 posts
Posted November 18, 2015 - 09:00 PM
The number on the bearing is the manufacturer part number which will be different than the ih number that is one the box
#4 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted November 18, 2015 - 09:14 PM
Haven't measured but its about double the size of the old bearing.
#5 dlang94 OFFLINE
dlang94
  • 245 Thanks
  • 169 posts
Posted November 18, 2015 - 09:19 PM
I see my mistake now, that bearing didnt need to be replaced so I was after the wrong bearing
Edited by dlang94, November 18, 2015 - 09:20 PM.
  • Tecumseh power said thank you
