Landlord question
6 replies to this topic
#1 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted November 18, 2015 - 01:30 PM
I was wondering if the bgb had its own oil or did it come from the trans. ? If it has its own do i just use gear oil?
Thanks,
luke
Edited by 637Yeoman, November 18, 2015 - 01:30 PM.
#2 boyscout862 ONLINE
  • 12,520 Thanks
  • 9,028 posts
Posted November 18, 2015 - 02:42 PM
Read the Manual. It has its own oil but I don't remeber what kind, the manual will tell. There is a drain plug and a fill/level plug but some have separate fill and level plugs. Good Luck, Rick
  • 637Yeoman said thank you
#3 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted November 18, 2015 - 03:00 PM
Book says 1 pint of SAE 90. 1.5 quarts of the same in the tranny.
There is a fill view hole, but reaching that is often overfilled.  Overfilling will result in seal leaks...the seals on these are to keep dirt out, not fluid levels in.  Many folks overfill unknowingly, then end up replacing seals, overfill, and after a while, have a 'seal issue' again.  There simply needs to be enough in there to keep it well lubed.
  • Gtractor, KennyP, boyscout862 and 2 others have said thanks
#4 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted November 18, 2015 - 09:49 PM
eah i seen that today, Thanks rick, Luke
#5 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
It seemed to have enough oil, If i can youch the oil in the bgb is that too full?
#6 Talntedmrgreen OFFLINE
  • 3,230 Thanks
  • 2,300 posts
Posted November 19, 2015 - 06:08 AM
Yeah...youre fine. I do like to pull the plug with the front elevated and drain them good if I suspect they have original juice in them. Get the grit out and refill.
  • boyscout862 and 637Yeoman have said thanks
#7 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted November 19, 2015 - 08:57 AM
it was kept well maintained so it prolly was changed recently. ill have to change it soon
