Wiring an ammeter.
11 replies to this topic
#1 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted November 18, 2015 - 01:05 PM
Got an ammeter with two terminals with nuts and a light bulb on it with a red and black wire. I have 2 wires coming into the ammeter, a black and a red. What is correct way to wire it up. The light bulb on the ammeter should only come on when headlight switch is turned on correct?
#2 chieffan OFFLINE
  • 10,194 Thanks
  • 6,657 posts
Posted November 18, 2015 - 01:46 PM
The light bulb needs to be wired into your light circuit.  The red from the amp gauge should go to the battery power source.  Probably the Bat terminal on the voltage regulator.  The black wire would  go to your ignition switch.  Hook it up that way and watch it when you turn the key to start the engine.  If the gauge reads to the negative side your in business.  If it reads positive, just switch the wires around on the gauge.
  • boyscout862 and Paulgo have said thanks
#3 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted November 18, 2015 - 01:57 PM
There are no wires coming from ammeter except for the tiny diameter light bulb wires which are black and red and only about 2 inches long. There are 2 wires black and red coming to the ammeter from wiring harness.
#4 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted November 18, 2015 - 02:39 PM
Ok I think I got ammeter hooked up right cause when I turn key in on position without starting, needle points towards discharge. Now I've tried light bulb both ways wired to ammeter and both ways the light always stays on even with key in off posistion?
#5 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted November 18, 2015 - 03:32 PM
Light bulb black wire to chassis ground, Light bulb Red wire to the switched side of your light switch. (You may need to extend the red wire.)
  • limebuzz and Cvans have said thanks
#6 Cvans ONLINE
  • 6,668 Thanks
  • 6,134 posts
Posted November 18, 2015 - 03:58 PM
:iagree:
#7 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted November 18, 2015 - 04:24 PM
Ok here is light switch. So hook red wire on which side?
Thanks
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted November 18, 2015 - 04:41 PM
To the terminal that is HOT only when switch is on
#9 coinman66 OFFLINE
coinman66
  • 178 Thanks
  • 295 posts
Posted November 18, 2015 - 04:51 PM
Ok thanks!
#10 toppop52 OFFLINE
toppop52
  • 5,273 Thanks
  • 4,770 posts
Posted November 18, 2015 - 04:59 PM
I have never understood why ammeters were used for so long, a simple volt meter provides more useful info and is far safer than running full current through a gauge.
#11 ol' stonebreaker OFFLINE
ol' stonebreaker
  • Validating
  • 1,690 Thanks
  • 1,148 posts
Posted November 18, 2015 - 05:54 PM
Agreed!!
                     Mike
#12 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,010 Thanks
  • 4,418 posts
Posted November 18, 2015 - 06:38 PM
I agree also, several times I have needed a volt meter to ascertain whether the battery was charging or not (or getting enough charge). The Amp meter can tell the same, just not as accurate with the low amperage output of a GT alternator. The Amp meter can contribute greatly with starting and charging issues as the high current is passed through them, and makes for additional points of connection failure or corrosion. A failed voltmeter will have no impact on the overall system.
