Wheel Horse 633
4 replies to this topic
#1 det12187 OFFLINE
det12187
  • 46 Thanks
  • 63 posts
Posted November 18, 2015 - 12:52 PM
Hello all,
I have an opportunity to buy a model 633 wheel horse, its not running at present,
owner says it has no spark. I was was wondering if this tractor would make a
good work tractor, mower deck looks great, tires are good and transmission will
shift through the gears, It is not rusty junk. I want to use it for mowing grass, plowing
snow and maybe putting a  mold board plow on it and/or disk. The price of $375.00 seems
a bit high for a non running tractor. Would appreciate some input from the forum.
Thanks Much,
#2 HANKG ONLINE
HANKG
  • 6,539 Thanks
  • 3,509 posts
Posted November 18, 2015 - 01:21 PM
1963  7 hp  K141 the tractor looks very nice and it will work , see if you can get for 300.00 you can always come up.
  • boyscout862 and det12187 have said thanks
#3 jabelman OFFLINE
jabelman
  • 2,238 Thanks
  • 1,600 posts
Posted November 18, 2015 - 01:59 PM
Looks like a good machine. probably just needs the points cleaned. check the gears on the mower deck.
I can't complain about my 854. I bought it and set up to use. rear attachments are sleeve hitch.
#4 KC9KAS OFFLINE
KC9KAS
  • 5,445 Thanks
  • 4,712 posts
Posted November 18, 2015 - 07:27 PM
Nice looking WH.
I agree, it may be a little high priced,  but then again location, supply & demand play a big part.
#5 Racinbob OFFLINE
Racinbob
  • 76 Thanks
  • 68 posts
Posted November 21, 2015 - 07:35 AM
That may be a bit high but not outrageous. A very common problem with the transmission is popping out of 3rd gear under a load. You'll be needing 3rd to push snow. Unfortunately, with the motor not running you can't check it. If you do get it and find you have that problem it's not a hard fix but that pesky 3rd/2nd gear (#3523) can be a bit hard to find and pricy when you do find one.
