Picked up a ford 1000
22 replies to this topic
#16 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 20, 2015 - 09:13 PM
$125 to have the starter repaired, PO overheated it
That seems like a fair price.
#17 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 20, 2015 - 09:27 PM
Didn't think that was to bad.  Steers hard so next thing is to replace the thrust washers their only 15 bucks each at Weavers
#18 Cvans OFFLINE
  • 7,065 Thanks
  • 6,285 posts
Posted November 20, 2015 - 11:24 PM
Steers hard
Check the steering gear box to see if it has grease in it.
#19 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 21, 2015 - 12:30 AM
Also make sure all joints are lubed( there are a bunch). And check front tire pressure.
My 1500 steers hard if tires are low. Even with 3 33 lbs weights on the front, the 5 ft brush mower makes the front end light. As does my tiller that is over 400 lbs.
#20 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 21, 2015 - 07:26 AM
Will do.  Got my repair manual from ebay yesterday also for $ 6  I'll start at the box and go through everything out to the bearings
How your 1500 handle the brush hog ?
Edited by baerpath, November 21, 2015 - 07:33 AM.
#21 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 21, 2015 - 04:00 PM
I am surprised at how well it handles the brush hog. Like I said I do not pick it up( let it ride on the trail wheel), but it mows well enough I have not yet bought a finish mower. I have to get in some tough stuff to get into the governor . I do blow the dust and pollen out of the radiator about every 4 hrs or it will run hot. A couple hours of dandelion fuzz will pack the screen up bad.
Take good care of the water pump, they are about $ 130 . I replaced one, then ran the belt too tight and took the bearings out of it and had to replace it this spring.
I am working on my third year on 9 acres and water pumps, and battery is all I have replaced. Do need a new cable for the tach, but it does not effect it's running.
I do need a steering wheel, 2 of 3 spokes are broke. Use the handles on the fender or steering wheel mast to pull yourself up and you won't break yours like I did.
Edited by JD DANNELS, November 21, 2015 - 04:13 PM.
  • Cvans said thank you
#22 Utah Smitty OFFLINE
Utah Smitty
  • 1,705 Thanks
  • 1,789 posts
Posted November 22, 2015 - 12:12 AM
Looks good.  I like those little Shibaru built Fords.  I currently have my one buddys 4WD 1100 Ford torn apart.  His needs a new clutch on it as it won't disengage and the travel is all used up.  Just for a new pressure plate and clutch disk and throwout bearing and a couple seals it's over $500.00  He got a smokin deal on his as well.  Tractor with a rear mounted Ford finish mower and the front mount snow blade for $1700.00.  Hoping to get the parts for it soon to get it back together for him before winter hits.
Many of those Japanese-built machines used the same clutches, starters, etc.  You might try Hoye Tractor--they specialize in Grey market Yanmars, but the disc off one of the Yannys may fit your Ford.
Smitty
Edited by Utah Smitty, November 22, 2015 - 12:25 PM.
#23 Bolens800uk OFFLINE
Bolens800uk
  • 1,820 Thanks
  • 1,201 posts
Posted November 22, 2015 - 09:20 AM
That's a very tidy one you got there. Over here in the UK it would be well rusted out.
  • olcowhand said thank you
