Picked up a ford 1000
22 replies to this topic
#1 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 17, 2015 - 08:53 PM
Picked this up, had to tow it to start, didn't take much to start it and it runs good. Need to repair the bucket but that's minor.    Looking for a starter for it Ford wants $1000 for one, That's more than I gave for it so would like to find one cheaper.
  • olcowhand, Gtractor, tractorgarden and 4 others have said thanks
#2 Trav1s ONLINE
Trav1s
  • 3,283 Thanks
  • 4,347 posts
Posted November 17, 2015 - 09:44 PM
Diesel?  Looks like a versatile size machine.
#3 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 17, 2015 - 09:58 PM
Nice looking Ford! Hope you enjoy it as much as I like my 1500!
Is there an automotive electrical shop in your area? More than likely they can rebuild it for much less than a new one would cost.
Also you could check an auto parts store, I find NAPA carries more tractor parts than you might think.
New Holland dealers should wear a gun when they hold you at the parts counter, it would seem more honest!
  • Alc, KennyP, Cvans and 2 others have said thanks
#4 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 17, 2015 - 10:20 PM
Yes 25hp 2 cylinder diesel
I took the starter off today, taking to get it checked out in the morning. Surprising how much it will lift I was comparing it to the 720 Allis (about the same size) but this will out lift and carry that
  • Trav1s and boyscout862 have said thanks
#5 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 17, 2015 - 11:09 PM
Yeah that is about 5 hp more than mine and about 500 lbs heavier. I do not have a loader but use mine every week if not more.
#6 KC9KAS ONLINE
KC9KAS
  • 5,382 Thanks
  • 4,689 posts
Posted November 18, 2015 - 05:15 AM
Nice tractor/loader!
#7 KennyP OFFLINE
  • 38,172 Thanks
  • 45,835 posts
Posted November 18, 2015 - 06:03 AM
Very nice 1000 you picked there!
#8 chieffan OFFLINE
  • 10,088 Thanks
  • 6,612 posts
Posted November 18, 2015 - 09:08 AM
Those are a nice outfit.  Had one when I worked for the state many years ago.  About any electric motor repair place should help you out on that starter.
#9 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 18, 2015 - 09:19 AM
Hey I got out my Stevens Tractor catalog this morning. They are in Coushatta, Lousianna.
I have bought two water pumps from them.
They list the starter for the 1000 at $389.95 , I think that is still a load but they are available for less than a grand.
So check around.
#10 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,204 Thanks
  • 5,802 posts
Posted November 18, 2015 - 12:24 PM
Probably just needs a set of brushes
#11 637Yeoman OFFLINE
637Yeoman
  • 1,551 Thanks
  • 1,254 posts
Posted November 18, 2015 - 01:26 PM
That thing is sweet! :thumbs:  :D
#12 olcowhand ONLINE
  • 41,004 Thanks
  • 31,371 posts
Posted November 18, 2015 - 03:24 PM
A reputable starter repair shop should go through it for $150 or so.  You got a great deal by the way!
  • Cvans said thank you
#13 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 18, 2015 - 06:49 PM
Took it down for testing today, PO overheated it and wiped out the solenoid. They called 3 suppliers and couldn't get the correct one.  He's gonna keep looking.
 Can't complain on the price  PO probably called Ford about a starter then decided the heck with it lol
  • olcowhand said thank you
#14 IHCubGuy ONLINE
IHCubGuy
  • 1,502 Thanks
  • 1,583 posts
Posted November 18, 2015 - 08:41 PM
Looks good.  I like those little Shibaru built Fords.  I currently have my one buddys 4WD 1100 Ford torn apart.  His needs a new clutch on it as it won't disengage and the travel is all used up.  Just for a new pressure plate and clutch disk and throwout bearing and a couple seals it's over $500.00  He got a smokin deal on his as well.  Tractor with a rear mounted Ford finish mower and the front mount snow blade for $1700.00.  Hoping to get the parts for it soon to get it back together for him before winter hits.
#15 baerpath OFFLINE
baerpath
  • 314 Thanks
  • 514 posts
Posted November 20, 2015 - 07:39 PM
$125 to have the starter repaired, PO overheated it
