B&S Starter gear
7 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 17, 2015 - 05:48 PM
Getting to be a wiz at changing these Briggs plastic starter gears...2nd one in 2 months and the first one took around an hour and a half...this one 20 minutes total.
Better than replacing flywheels but, one would think they would make them just a tad more durable.
#2 KennyP ONLINE
  • 52540 Thanks
  • 53104 posts
Posted November 17, 2015 - 05:50 PM
My thoughts exactly!
  • Phluphy said thank you
#3 Bolens 1000 OFFLINE
  • 17492 Thanks
  • 18846 posts
Posted November 17, 2015 - 05:56 PM
They are pretty simple once you do it a time or two, its not a bad idea and definitely cost effective compared to buying a new ring gear or starter!
#4 EricFromPa OFFLINE
EricFromPa
    Fixer of Broken junk
  • 6771 Thanks
  • 4562 posts
Posted November 17, 2015 - 06:24 PM
I like to change both the Ring gear and starter gear if there is Any wear what so ever on the ring gear.All it takes is 1 small nick or a bit of wear on the ring gear to mess up the nylon starter gear.
I like to pull the starter apart and check the bushings while I'm at it.If the starter bushings get a bit worn it causes the starter gear to sit shallow in the ring gear.Especially when cranking the engine over.
I think it's $10-15 for a new ring gear or $18-$20 for the kit.Drive out the 4 pins and bolt the new one on.Very simple job.
Replacing Starter bushings can be a pain in the butt BUT it will make your starter and starter gear last a long time.If you can find bushings that fit your particular starter.
  • Alc, boyscout862 and Phluphy have said thanks
#5 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7963 Thanks
  • 4741 posts
Posted November 17, 2015 - 10:29 PM
I have replaced the nylon gears also. Mine are still good after 3 years, I also replaced the brass bushings in the starter. I think this allows the gears to mesh evenly resulting in longer life.
  • Alc, EricFromPa, KennyP and 1 other said thanks
#6 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 18, 2015 - 12:25 AM
Thinking you are right on this idea. Next time it happens, not rushed for time here, I'll take the starter apart to check those bushings. If they are worn I'll just put a new or rebuilt starter on it. Seems odd there is a nearly perfect area on the pinion gear than gets evenly worn, just as it would if it weren't meshing deep enough. Snugged the heck out of the mounting bolts in case I allowed for a bit of play on the last go around.
Ring gear looks sharp on all teeth, i.E., no noticeable wear, square cut shoulders.
Thanks
#7 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 18, 2015 - 12:31 AM
You must have someone looking after you...I've never had one of these gears, vertical driver or horizontal, last even a full year, but then, in the course of an average day it's probably operated 15-30 times.. Think it's time to sell a tater or two and pick up a new starter.
Back to dragging logs.
Thanks
#8 larrybl OFFLINE
larrybl
    Texas Member
  • Site Supporter
  • 7963 Thanks
  • 4741 posts
Posted November 18, 2015 - 08:54 AM
Yes, usage will make a difference, I had to rebuild Hulk's starter after using him and the trailer as a portable work bench while building my shop, funny though, I only had to replace the top bushing, and magnet housing, the gear was still fine.
