I got me a Jim Dandy this time
13 replies to this topic
#1 Merle013 ONLINE
Merle013
    If I can't do it slow then it's not going to get done.
  • 257 Thanks
  • 180 posts
Posted November 17, 2015 - 05:47 PM
I just purchased a 1965 Jim Dandy. The restoration was started but he lost interest and unfortunately the wiring harness too. It has set out in the weather for the last year. Got to pick up some fluids though. He drained everything for the restore but did not replace them yet. Someone went insane and painted the two left wheels silver and the two right wheels yellowish-green. He did do a good job on the sand blasting. There is no rust to be found. The rear tires are new. The front tires look new until you get close. They have all the tread on them but they are completely weather rotted. He also threw in a half a dozen gasket sets for Briggs, Tecumseh and Kohler.
  • olcowhand, Alc, KennyP and 6 others have said thanks
#2 KennyP ONLINE
  • 35,120 Thanks
  • 44,131 posts
Posted November 17, 2015 - 05:55 PM
The silver wheels don't look bad! Are you sure the other side isn't a primer?
  • boyscout862 and Merle013 have said thanks
#3 Delmar ONLINE
Delmar
  • 2,626 Thanks
  • 2,639 posts
great tractor!  congrats!
  • Merle013 said thank you
#4 grattone OFFLINE
grattone
  • 309 Thanks
  • 219 posts
Posted November 17, 2015 - 06:48 PM
That makes me feel real old, I worked on those back in the late 60's and can not remember. How do you put the starter / generator belt on ???
#5 David Brown OFFLINE
David Brown
  • 4,510 Thanks
  • 2,424 posts
Posted November 17, 2015 - 06:56 PM
Nice little tractor.  If I read the serial numberright, it's actually a 1964.  Either way it's a very desireable model with that round hood.  Great little tractors.
#6 Merle013 ONLINE
Merle013
  • 257 Thanks
  • 180 posts
Posted November 17, 2015 - 07:30 PM
I guess it could be primer. Does not matter. That side is definitely getting painted. As far as the belt goes. I was advised to use an adjustable v-belt. They are quite expensive but it saves having to pull an engine. The hydraulic pump on my PK uses the same mounting setup. Has same issue.
#7 MNGB ONLINE
MNGB
  • 1,715 Thanks
  • 1,225 posts
Posted November 17, 2015 - 08:16 PM
Good looking tractor, I'm also thinking the green wheel could be primer, the good think is the PO painted them before he lost interest so no serious rust. Good luck with you project keep us post updated.
#8 Tecumseh power OFFLINE
Tecumseh power
  • 1,453 Thanks
  • 1,103 posts
Posted November 17, 2015 - 08:53 PM
Those things are so neat I always wanted one but I could never find a good deal. Online is the only place I've ever seen them for sale I never saw one in real life. How many horsepower is that briggs, good find
#9 jabelman OFFLINE
jabelman
  • 1,992 Thanks
  • 1,467 posts
Posted November 17, 2015 - 09:47 PM
that yellow looks like zinc chromate
#10 Merle013 ONLINE
Merle013
  • 257 Thanks
  • 180 posts
Posted November 17, 2015 - 11:12 PM
Its a 23DFB with 9HP.
  • Tecumseh power said thank you
#11 karel ONLINE
karel
  • 1,861 Thanks
  • 1,248 posts
Posted November 18, 2015 - 12:36 AM
That's a nice machine.
#12 Alc ONLINE
  • 6,437 Thanks
  • 7,241 posts
Posted November 18, 2015 - 06:16 AM
It's a very nice tractor :thumbs:   I like the had brake controls , do you think the seat spring/support is original ?  It seems high but might just be the pictures .
#13 Merle013 ONLINE
Merle013
  • 257 Thanks
  • 180 posts
Posted November 18, 2015 - 10:50 AM
The seat spring is original as far as I know. This is my first Jim Dandy so I could be mistaken. It looks correct in the catalog I have.
#14 Merle013 ONLINE
Merle013
  • 257 Thanks
  • 180 posts
Posted November 19, 2015 - 07:34 PM
Thanks for the correction it is a 1964.
