1964? Landlord 9hp
5 replies to this topic
#1 637Yeoman OFFLINE
637Yeoman
    The Simplicity collector
  • 628 Thanks
  • 617 posts
Posted November 17, 2015 - 01:32 PM
I got a 1964? landlord with a serial number of 004820. Was wondeing if someone could look up the year for me. Also, How many did they make until switching to the 101 landlord? This tractor is a step down from that, The 9hp landlord black dash. Thanks, Luke
  • Talntedmrgreen and HANKG have said thanks
#2 boyscout862 OFFLINE
  • 10,493 Thanks
  • 7,921 posts
Posted November 17, 2015 - 01:35 PM
Did you look through our Manuals Section? You are allowed 3 free downloads per day. I thought that there was a chart that gave the dates for serial numbers. Good Luck, Rick
  • 637Yeoman said thank you
#3 Talntedmrgreen ONLINE
  • 3,122 Thanks
  • 2,214 posts
Posted November 17, 2015 - 01:46 PM
There are no dates recorded for Simplicity serial #'s...Simplicity never kept those records, which is kinda a bummer.  The '64 Landlord was the only model to have the black dash and a 9hp (3 bolt carb) Briggs.  The Briggs should be dated '63 or '64, if original.
The Landlord 101 is also a single model year machine, with a 10hp Briggs...1965.  After that, the Landlord became the 2010 & 2012, with 10 & 12 horsepower, respectively.
In '68, it became the 2110, and had new 'flathood' sheetmetal.  The 12hp equivalent was the new 'Sovereign 3012', with variable drive.  This year also saw the round fenders vanish.  In late '68- '69 the Landlord had some minor changes (key start, neutral safety switch, round steering wheel & updated mid PTO) as it became the 2210...the last footdragger Landlord, last appearing in 1970.
  • boyscout862, TomLGT195 and 637Yeoman have said thanks
#4 637Yeoman OFFLINE
637Yeoman
  • 628 Thanks
  • 617 posts
Posted November 17, 2015 - 01:53 PM
So it is a 1964 then, thanks for the info.
#5 HANKG OFFLINE
HANKG
  • 5,385 Thanks
  • 2,985 posts
Posted November 17, 2015 - 03:03 PM
Yes it is with out a doubt
#6 grattone OFFLINE
grattone
  • 308 Thanks
  • 218 posts
Posted November 17, 2015 - 06:37 PM
http://www.tractorda...9hp-engine.html
Take a look at this it may help..
