Today's 100 dollar haul gt18 tecumseh . Ltv11
#1
OFFLINE
Posted November 16, 2015 - 07:13 PM
- Traill95, Dieselcubmike and Marlin1963 have said thanks
#2
OFFLINE
#3
OFFLINE
Posted November 17, 2015 - 07:55 AM
I would love to get a hold of an OH180, really like my 16's so I probably would love the torque of the 18.
You may want to measure the rearend mounting pads before you get in too deep. While they used the same rear axle, the mounting tabs on the newer models where wider so it may not fit. I don't know what years it changed, but I remember seeing a swap done on recently on another forum and guy had to make spacers, I think he used and older tranny in a newer tractor.
- Tecumseh power said thank you
#4
OFFLINE
Posted November 17, 2015 - 09:03 AM
#5
OFFLINE
Posted November 17, 2015 - 11:05 AM
thanks Tahoe, they both go in with spacers, it looks to me that sears just used wider spacers on the newer one. I will be able to fabricate it to fit I'm sure of it. I can make spacers and brackets if I have too. The guy said the tranny was grinding when you try to put it in gear , but alot of them do that anyways until it stops spinning all the gears work. Maybe it's just a bent shift fork. I never had one of those kind apart so I can't really guess without ripping into itI would love to get a hold of an OH180, really like my 16's so I probably would love the torque of the 18.
#6
OFFLINE
Posted November 17, 2015 - 12:19 PM
Uhm that's weird, my suburban didn't have any spacers when I pulled tranny, it would be the same as your 78.
Mine grinds quite often, I think my clutch needs adjusted cause input pulley spins for quite a bit before it finally stops. I think my belt isn't disengaging completely.
#7
OFFLINE
Posted November 20, 2015 - 02:12 PM
- TAHOE said thank you
