Kohler "K" balance gears.......
9 replies to this topic
#1 poncho62 ONLINE
poncho62
  • 2,102 Thanks
  • 1,775 posts
Posted November 15, 2015 - 09:04 PM
I recently rebuilt a K341...the balance gears were very wobbly, so we left them out. Engine runs fine and shakes very little.
I am now doing a K321. The balance gears are much better, but do wobble very slightly. Probably going to leave them out again, but just thought I would get so opinions and previous experiences about this. What you say?
  • Oldford and holdenboy1960 have said thanks
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,449 Thanks
  • 4,570 posts
Posted November 15, 2015 - 09:08 PM
I took them out on my K321, no issues.
  • Alc and holdenboy1960 have said thanks
#3 tractorgarden OFFLINE
tractorgarden
    Junk Whisperer
  • 1,294 Thanks
  • 1,443 posts
Posted November 15, 2015 - 09:16 PM
I leave them out also!
#4 LilysDad ONLINE
LilysDad
    Anything Red . . .
  • 14,100 Thanks
  • 10,171 posts
Posted November 15, 2015 - 09:34 PM
My K341 genset never had them.
#5 propane1 ONLINE
propane1
  • 9,419 Thanks
  • 4,373 posts
Posted November 15, 2015 - 10:13 PM
Out. Noel
#6 dodge trucker ONLINE
dodge trucker
  • 2,805 Thanks
  • 3,438 posts
Posted November 15, 2015 - 10:44 PM
I left them out on my 12hp Magnum, we will see how much difference it makes once I get it fired up once again.
and they actually still felt pretty tight, kicked it around in my head a bit like you are, decided to leave em out anyway.
Edited by dodge trucker, November 15, 2015 - 10:45 PM.
#7 holdenboy1960 OFFLINE
holdenboy1960
  • 1,749 Thanks
  • 941 posts
Posted November 16, 2015 - 05:48 AM
i thought they also acted as a ballast weight for timing similar to a small fly wheel ect .......................but  not sure
#8 poncho62 ONLINE
poncho62
  • 2,102 Thanks
  • 1,775 posts
Posted November 16, 2015 - 05:50 AM
Thanks all.....they shall hit the scrap bin
#9 olcowhand ONLINE
  • 42,885 Thanks
  • 31,934 posts
Posted November 16, 2015 - 07:25 AM
When into one with gears, I button the engine up without them.
#10 RAJ OFFLINE
RAJ
    JMC fan
  • 324 Thanks
  • 323 posts
Posted November 16, 2015 - 02:12 PM
I know a local machinist that has decades of experience building Kohlers for garden tractor pulling. He says the same thing. The balancing gears are only going to cause problems if they aren't removed. I bought a low hour open sided Ford LGT165 with a destroyed block thanks to the failed gears. He did also say that poor maintenance is usually to blame for catastrophic failure.
