John Deere 110 wiring harness
4 replies to this topic
#1 hardwater1 OFFLINE
hardwater1
  • 8 Thanks
  • 7 posts
Posted November 15, 2015 - 12:14 PM
Has anybody made their own wiring harness for a John Deere 110. if so what gauge wire was used
Thanks :wave:
#2 chieffan OFFLINE
  • 11,789 Thanks
  • 7,287 posts
Posted November 15, 2015 - 01:26 PM
I use 14 & 16 ga. for all but the primary wires, where 10 or 12 will work.  Better to be a little heavy than light in the size.
  • hardwater1 said thank you
#3 josh deaven OFFLINE
josh deaven
  • 479 Thanks
  • 574 posts
Posted November 15, 2015 - 05:16 PM
Get a hold of agri services in New york they can make you a new one!
#4 lyall ONLINE
lyall
  • 2,250 Thanks
  • 1,602 posts
Posted November 15, 2015 - 08:35 PM
I have make several for my deere's 100 series and 200 series.
I got the wire connecters ( male and female) from my local Deere dealer for around 50 cent each.
I bought six different colors of 16 gauge wire and a red 12 gauge for the wiring from the battery to switch.
I do solder each connection.
Deere also the plastic housing for the wire connections.
  • Trav1s and hardwater1 have said thanks
#5 air4dave OFFLINE
air4dave
  • 1 posts
Posted February 01, 2016 - 03:32 PM
I don't know if you guys can help me here but it's worth a shot.
I have a JD 102 garden tractor and I found the hour meter for it that was, apparently, optional back when it was new in 2006.  It has the connector for the meter already installed so I got the correct part number from JD, which is a GY20528  It has the two male spade connectors and the harness has the "t" configuration on the connector.  It plugs right into the new meter.
Now, the problem: It won't come on.  The female connector has the blk and wh wires both going into the top part of the "t" and the yellow wire is going to the other part.  If I use a test light, clipping the ground to the battery -, as soon as I touch the yellow wire it will kill the engine.  With the engine not running, there is no power to either part of the connector.  When I turn the key on - not running - I still get no power to the connector.
I feel the blk and wh wires shouldn't be together but don't know why it came from the factory like this.
Any help here would be appreciated.
Thanks!
Dave
