My snow fightin team, pictures.
17 replies to this topic
#1 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 11:47 AM
Some of them any way. Not in the picture is the noma walk behind snow blower, MF 14 with plow, lgt 145 ford with snow blower, 1951 ferguson tractor with rear blade and a 1968 snow flight walk behind snow blower. Believe me, I don't want any snow, last year was bad.
Noel.
  • DH1, Gtractor, MH81 and 12 others have said thanks
#2 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted November 14, 2015 - 01:00 PM
How did you hook the rear blower on the Massey?
  • propane1 said thank you
#3 jabelman OFFLINE
jabelman
  • 2,243 Thanks
  • 1,606 posts
Posted November 14, 2015 - 01:14 PM
how do you decide which one to use?
#4 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 01:19 PM
Shorty, The lower arms are from a MF 7 deck, hooked into where the tiller hooks up. Piece of pipe on to the top lift arm to the a frame on thrower. A slot on the top pipe at the thrower end for float. Some helper springs. Realy need counter weight on right side because of the engine. Extra spring on motor side to help keep level. But when down it works good. It lifts like a 3 point hitch. Some pictures coming, Noel
Edited by propane1, November 14, 2015 - 01:19 PM.
  • DH1, daytime dave, shorty and 2 others have said thanks
#5 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 01:25 PM
Jabelman, Which ever one is not broke, is the one I use. No, the lgt 165 ford is the main one, the other ones are the toys, but still useful. If the ford breaks down, then it's onto the next one. Noel.
#6 michael.kitko OFFLINE
michael.kitko
  • 505 Thanks
  • 462 posts
Posted November 14, 2015 - 02:00 PM
Do you like the rear thrower? I am in the process of building an adapter bracket for a 49 on my 140.
#7 shorty ONLINE
shorty
  • 5,833 Thanks
  • 5,414 posts
Posted November 14, 2015 - 02:04 PM
I like that setup. I have been kicking around the idea for a few years now. Just wasn't sure how to deliver the power. I was hoping to get the power from the pto versus another engine.
  • michael.kitko and propane1 have said thanks
#8 boyscout862 OFFLINE
  • 13,552 Thanks
  • 9,427 posts
Posted November 14, 2015 - 02:38 PM
Nice herd. Have you tried the headlight cleaning stuff on the plastic windows of the cab? I was thinking about trying it but can't get at the cabs yet. Good Luck to us all this winter. Rick
#9 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 02:53 PM
Rick. I just tryed some stuff on the cab windows. Works good. Will put a picture of it on here soon. Noel.
#10 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 03:01 PM
Shorty, I wanted to do the same, use the tractor engine, but could not figure out a way to do it and in order for the thrower to work, you would have to have full engine speed, which would make the tractor to fast in reverse to be comfortable. Tractor is geared not hydro. So, I went the engine route. Just idle the tractor in reverse and it's easy to use. I ran fuel line from the tractors gas tank to operate the motor. Ran electric for the starter. Have a extra key switch on the dash. Noel
The engine is 8 hp, really could use a 10 hp.
Edited by propane1, November 14, 2015 - 03:10 PM.
  • shorty and michael.kitko have said thanks
#11 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 03:06 PM
Michael.kitko, I like it. It's fun. But harder on the back and neck. Nice to be able to use the loader, then the thrower with out changing tractors. Noel.
  • michael.kitko said thank you
#12 propane1 ONLINE
propane1
  • 9,446 Thanks
  • 4,388 posts
Posted November 14, 2015 - 04:05 PM
Rick. This is what I used to clean the cab windows.
#13 UncleWillie ONLINE
  • 16,253 Thanks
  • 8,970 posts
Posted November 14, 2015 - 06:44 PM
My snow fighting team.
  • daytime dave, MH81, KennyP and 7 others have said thanks
#14 daytime dave ONLINE
  • 4,963 Thanks
  • 6,596 posts
Posted November 14, 2015 - 07:30 PM
Noel, that team looks very capable indeed.
Nice job on the rear mounted snow blower as well.
#15 Marty'70 ONLINE
Marty'70
    I didn't do it! Unless you have paperwork to back it up
  • 871 Thanks
  • 722 posts
Posted November 14, 2015 - 07:41 PM
must be nice Willie!
