Sears custom 6
7 replies to this topic
#1 tinkerbob OFFLINE
tinkerbob
  • 3 Thanks
  • 1 posts
Posted November 13, 2015 - 09:47 PM
I have a set of sears tractor attachements. I have a 3 point hitch, a plow, disc, cultivator, back blade and a push blade.
I have an oppotunity to buy a sears custom 6 tractor. i know the hitch will fit it but will the little bugger pull the plow, disc and cultivator through the dirt.
I am going to buy the tractor but wont be able to set it up and try it til spring. The tractor is in great condition and runs like a champ. all the gears work well mower deck works well. $250
I do not have pics of any of this but maybe in the spring.
  • Alc, Traill95 and HANKG have said thanks
#2 craftsmanmowerfreak OFFLINE
craftsmanmowerfreak
  • 288 Thanks
  • 232 posts
Posted November 13, 2015 - 11:45 PM
yes the custom will pull attachments not has good has a sub but it will do a good job
#3 MH81 OFFLINE
Posted November 14, 2015 - 12:21 AM
The common plow size for the Custom was the 8" (they did have a 6" too)
Even tho I've found zero reference to a 7", I own one.
The std size for the Suburbans is a 10". The general rule of thumb is 1" per hp. However, My experience is that you can plow with less than that, just not as fast. The Custom tractors are tougher than people think, give it a try and I think you'll be surprised.
One word of caution on the 6 hp engine. It's not steel sleeved so oil changes are hyper critical. Also, if you're going to work it, you may want to go synthetic.
  • Traill95 said thank you
#4 Alc OFFLINE
  • 6,905 Thanks
  • 7,468 posts
Posted November 14, 2015 - 06:21 AM
Welcome to GTTalk ! Looking forward  to seeing your tractor my first tractor was a Custom 6 and I wish I would have kept it .
#5 boyscout862 OFFLINE
  • 12,864 Thanks
  • 9,176 posts
Posted November 14, 2015 - 06:47 AM
Welcome to GTT. Check our Manuals Section for info. Good Luck, Rick
#6 jd.rasentrac ONLINE
jd.rasentrac
  • 4,773 Thanks
  • 4,265 posts
Posted November 14, 2015 - 07:37 AM
:welcometogttalk:
#7 wahoowad OFFLINE
wahoowad
  • 49 Thanks
  • 68 posts
Posted November 14, 2015 - 07:45 AM
I think it will do fine. I had a Custom 7 that did not blink at pushing snow or breaking up my packed driveway. My 7hp engine didn't always run as smooth as I wanted yet it had plenty of power, even at only mid-throttle so we're talking about using much less than the rated hp.
07562773-DDB9-42F3-B0DE-D2617C7950D4_zps
94B9EEE7-D268-46AD-941F-33AF4DABC550_zps
#8 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,207 Thanks
  • 5,805 posts
Posted November 14, 2015 - 08:38 AM
:welcometogttalk:
