need help
2 replies to this topic
#1 1978murray OFFLINE
1978murray
    diesel mechanic
  • 607 Thanks
  • 1,165 posts
Posted April 18, 2011 - 07:00 PM
the briggs and stratton 170402 on my panzer doent want to run right, I know its a carb problem. it will idle smooth but when u throttle it up. it backfires and then smokes black. also the throttle arm on the carb goes crazy it bounces and makes everything run crappy. Now if you hold the throttle arm at about 3600 rpm it runs fine. but when u let it go it acts all up. IDK wats goin on.
#2 MH81 OFFLINE
Posted April 18, 2011 - 07:07 PM
Is the shaft loose enough to move up and down? If so, you may need to bush that one.
#3 caseguy OFFLINE
  • 1,628 Thanks
Posted April 18, 2011 - 08:18 PM
You took the words right out of my mouth! May even be sucking air around the shaft. There also may be a spring missing? There should be some kind of spring or linkage that holds the throttle stable in any given position. Any other thoughts on this?
