White GT1855 stopped moving
12 replies to this topic
#1 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted November 13, 2015 - 04:02 PM
Been running great, backed out of the shed today. Let run a couple of minutes then started to back up. Jolted backwards and I stopped it with the brake pedal. Now it won't move either direction. The lever moves freely in both directions but it does not move. Wonder what happened?
#2 boyscout862 OFFLINE
  • 13,545 Thanks
  • 9,425 posts
Posted November 13, 2015 - 04:28 PM
Check the fluid level. Check out any shear keys or pins. Find the parts manual to locate any possible pins. Good Luck, Rick
#3 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted November 13, 2015 - 04:47 PM
I will assume this is hydrostatic and ask if you have checked the linkage? That is as far as I will go I am sure someone with knowledge of your tractor will be along soon.
#4 Diesel1050 OFFLINE
Diesel1050
    Diesel Nut!
  • 379 Thanks
  • 418 posts
Posted November 13, 2015 - 05:17 PM
It is a hydro. Eaton M11 hydro and a Peerlesss 2560 transaxle. Sounds like you have air in the system. Replace fluid with 20 wt motor oil. Could also be a stuck blow-off valve, or a bad seal. Are you sure the hydro is pumping? Could have sheared the woodruff key....
#5 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted November 13, 2015 - 05:47 PM
I will start with those suggestions tomorrow.
Thanks
#6 glgrumpy OFFLINE
  • 8,803 Thanks
  • 8,009 posts
Posted November 13, 2015 - 09:40 PM
2 spd rear and it bounced out of position and is now in Neutral? Move back/forth to make sure it is going into the range selected, some times takes a good pull or push on lever/handle to get it in gear.
  • shorty said thank you
#7 toppop52 OFFLINE
toppop52
  • 5,531 Thanks
  • 4,898 posts
Posted November 13, 2015 - 10:40 PM
My 4041 has a three speed rear and I forget or accidentally get it in neutral every now and then.
#8 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted November 14, 2015 - 11:37 AM
THANKS SO MUCH!! The high/low lever was in high.so I moved it to neutral and back to high. ....bingo! Life is good again.
Thanks again.
Frank
  • olcowhand, KennyP and shorty have said thanks
#9 shorty ONLINE
shorty
  • 5,832 Thanks
  • 5,414 posts
Posted November 14, 2015 - 12:57 PM
Love it when it is such an easy fix.
#10 KennyP ONLINE
  • 40,855 Thanks
  • 47,081 posts
Posted November 14, 2015 - 05:20 PM
Thanks again.
Frank
Glad that worked for you! Couldn't ask for an easier fix!
#11 toppop52 OFFLINE
toppop52
  • 5,531 Thanks
  • 4,898 posts
Posted November 14, 2015 - 07:57 PM
Great!
#12 TAHOE OFFLINE
TAHOE
  • 8,296 Thanks
  • 5,797 posts
Posted November 16, 2015 - 08:18 AM
Glad it was an easy fix.
just to be aware, these machines can be bad for wearing out the splines on the input shaft of the hydro pump.
#13 Fdsinozich OFFLINE
Fdsinozich
  • 29 Thanks
  • 76 posts
Posted November 19, 2015 - 06:58 PM
Thanks
