solid state ignition
tecumseh
36 replies to this topic
#31 TAHOE OFFLINE
TAHOE
  • 8514 Thanks
  • 5931 posts
Posted February 23, 2016 - 05:11 PM
Definitely the switch. The internal contacts between the M terminal and G terminal burn causing a constant ground, has nothing to do with the rest of the switch circuits so it will spin starter,  lights may even work, but still ground out module.
Originally switch was a 4406R, plenty of places carry it, I know NAPA carries one for about $12.
Edited by TAHOE, February 23, 2016 - 05:12 PM.
  • limebuzz and Tecumseh power have said thanks
#32 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted February 23, 2016 - 05:47 PM
I will go through the wiring again one last time. And then if nothing I will head to Napa in the morning. Still waiting on the acid to clean the tank out and the carb leakes gas real bad still.
#33 DH1 OFFLINE
DH1
    Electric Tractors
  • 5496 Thanks
  • 5633 posts
Posted February 23, 2016 - 05:54 PM
I have 1 good small tank, spare one.
#34 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted February 23, 2016 - 06:52 PM
Thanks Doug,This one is really good, but what a gunky mess inside.
  • DH1 and MH81 have said thanks
#35 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted February 24, 2016 - 12:38 AM
So tonight I hooked up a temporary fuel tank and threw a different carb together and tried to start the 10.now I don't know how long this thing has sat,but itit started before the first complete revelution. Not bad, but man does it run like crap. Lol. I set the timing to 009,but it don't sound right. The governer constantly hunts. Backfires the odd time and blows black smoke.i added some ATF to the oil,and sea foam to the fuel. I'm going to let it run some more in the morning and see if it clears up a bit better. All in all, im happy that this thing if finally running.
  • MFDAC said thank you
#36 MFDAC OFFLINE
MFDAC
  • 3700 Thanks
  • 1769 posts
Posted February 25, 2016 - 08:40 PM
I've never messed with an MF10 but I do have a 10 HP Tecumseh on my MF8E. What you are describing still sounds more like flooding than a timing issue to me. An over-rich fuel mixture normally backfires out the exhaust, along with the black smoke you described and an over-lean fuel mixture will backfire through the carb. When I was dealing with the flooding issues with the Honda clone engine the governor on it was constantly hunting too.
Hope you got it running better by now!----DAC
  • limebuzz said thank you
#37 limebuzz OFFLINE
limebuzz
  • 1155 Thanks
  • 1083 posts
Posted February 25, 2016 - 08:44 PM
Thanks Doug, never got to it today. I finally found an ignition switch for it today. The ole lady was picking it up today for me. So first thing in the morning I will install it and fiddle with the carb settings.
Also tagged with one or more of these keywords: tecumseh
