430 alternator seized
5 replies to this topic
#1 jj69chev OFFLINE
jj69chev
  • 24 Thanks
  • 150 posts
Posted November 11, 2015 - 05:33 PM
Just like the title says, my alternator seized up out of nowhere. anyone know if it can be rebuilt or am I on the hook for a new one?
Thanks in advance
#2 boyscout862 OFFLINE
  • 13,446 Thanks
  • 9,392 posts
Posted November 11, 2015 - 06:18 PM
Pull it apart and see. It used to be about $12 for a kit to rebuild GM alternators. Hopefully it is just a bearing. Good Luck, Rick
Or, take it off and take it to a rebuilding shop for an estimate to compare with a new one.
Edited by boyscout862, November 11, 2015 - 06:19 PM.
  • jj69chev and Alc have said thanks
#3 olcowhand ONLINE
  • 42,485 Thanks
  • 31,832 posts
Posted November 11, 2015 - 06:19 PM
The bearings are replaceable, but not sure if JD offer them.  I'd take it to a rebuilder & let them replace what's needed.
#4 olcowhand ONLINE
  • 42,485 Thanks
  • 31,832 posts
Posted November 11, 2015 - 06:24 PM
If you're comfortable taking it apart, then by all means do.  It may be more than just a bearing if the rotor hit the fields.  If so, check THIS out.
#5 chieffan OFFLINE
  • 10,954 Thanks
  • 6,944 posts
Posted November 11, 2015 - 07:04 PM
Most electric motor repair shops will repair alternators, starters, generators, etc.  They would be much cheaper than JD would.  JD would charge you $50 just to drive on their lot.  My opinion of JD brand.
#6 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 12, 2015 - 09:25 AM
I agree, I have found a rebuilder is your best bet. We haves guy here in town who is quicker, better and less expensive tha parts houses and dealers.
  • jj69chev said thank you
