Lost a spring
6 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 10, 2015 - 08:29 PM
Craftsman II GT Model Number 917.255919, part #7190J. It's the spring that operates the bracket for 2 idler pulleys under front of tractor. Drive belt for deck runs in the pulleys.  Anyone know where I can get one?
Ones I'm finding say No longer available".
Thanks
#2 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted November 10, 2015 - 10:05 PM
Check with your local ACE hardware, that is where I have been obtaining my NLA springs from.
  • Alc and Phluphy have said thanks
#3 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 11, 2015 - 09:40 AM
Will do. Two problems are...I don't have a clue as to how long it was nor tension required.
Thanks
#4 KennyP ONLINE
  • 38,513 Thanks
  • 45,987 posts
Posted November 11, 2015 - 03:01 PM
Thanks
That sounds like the 'mule' drive. Cannot get Sears Parts to bring that up, but I have one in the garage. I'll see what it looks like.
Is this what you are looking at?
  • Phluphy said thank you
#5 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 11, 2015 - 10:48 PM
Exactly. Went to Ace today and picked up a "maybe it'll work" substitute. Haven't tried it yet. Will do tomorrow. If it doesn't do the job I'll get back to you.  Thanks
#6 larrybl ONLINE
larrybl
    Texas Member
  • Site Supporter
  • 7,011 Thanks
  • 4,418 posts
Posted November 12, 2015 - 09:01 AM
I was going to pull my spring off so to measure, the ends are coiled almost completely around the bottom mount which would require removeing the stand off bolt at the bottom to get the spring off. I guess it was done this way to prevent the spring from popping off easily. I would make sure the spring end loop is as closed as possible If you can. I have had "some" luck with heat when I needed to twist one of the spring ends around, I would think closing the end up would be easier.
  • KennyP and Phluphy have said thanks
#7 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 12, 2015 - 12:20 PM
Yepper, the spring from Ace has nearly closed ends, in fact the one in your photo looks exactly like it.  Thinking I'll pull the anchor bolt and run it through the eye of the spring rather than risk snapping end off.
Thanks
Second look at yours...they aren't the same.  Yours has a longer reach on the one end. Will get back to you if my idea doesn't work.
Thanks again
Hot damn!  It worked.
Edited by Phluphy, November 12, 2015 - 05:00 PM.
