For Sale
Heavy Duty Air Cleaner Assembly
3 replies to this topic
#1 farmerall OFFLINE
farmerall
  • 2,201 Thanks
  • 1,473 posts
Posted November 10, 2015 - 06:38 PM
For sale is a HD air cleaner. Perfect gt size and it would look great on a diesel repower. It's in good condition apart from the plastic sediment bowl. New sediments bowls are available with some searching. Pop can for scale.
Asking 40 obo.
#2 chieffan ONLINE
  • 8,800 Thanks
  • 6,035 posts
Posted November 10, 2015 - 08:02 PM
I believe you have a Donaldson oil bath air cleaner.  The part with the plastic bowl is the per-cleaner and goes on the end of the cleaner.  The cup with the clamp is the oil container and is at the bottom.  Cup probably has a line stamped into the side for oil level indication.  Have one just like in on my IH 400.
#3 farmerall OFFLINE
farmerall
  • 2,201 Thanks
  • 1,473 posts
Posted November 10, 2015 - 08:41 PM
This one is made by Donaldson too but it's a dry element filter. You are correct, it looks very similar to the ones used on old Farmalls however this one is made to mount horizontally as pictured.
  • boyscout862 and chieffan have said thanks
#4 chieffan ONLINE
  • 8,800 Thanks
  • 6,035 posts
Posted November 10, 2015 - 11:38 PM
If it is a dry filter I can see how it should work horizontally like you said.  Thanks for the education.  First dry element unit I have seen.
