Wheel Horse K181
4 replies to this topic
#1 MAV OFFLINE
MAV
  • 110 Thanks
  • 215 posts
Posted April 18, 2011 - 02:12 PM
Would anyone know what size the output shaft on a K181 out of a Wheel Horse would be?
Thanks,
Mark
#2 GWest OFFLINE
GWest
  • 547 Thanks
  • 499 posts
Posted April 19, 2011 - 04:58 AM
1" OD but do not know the length.
Garry
#3 caseguy OFFLINE
  • 1,628 Thanks
Posted April 19, 2011 - 03:29 PM
Garry
That sounds right to me. I believe that most of the Kohlers (and Tecumsehs' for that matter) on the Wheel Horses had the 1" output shaft.
#4 GWest OFFLINE
GWest
  • 547 Thanks
  • 499 posts
Posted April 19, 2011 - 05:22 PM
Had to check cause you got me to wondering.
The horizontal Kohlers, Onans and Tecumsehs 10hp and up are all 1-1/8" shaft. The Charger 9 is also.
The Briggs and Strattons used in the WorkHorse models are all 1".
The first manual pto clutches were different. In the end the horizontal pto clutches are all the same. The difference is the diameter of the hardened sleeve the needle bearing runs on. Comes in handy if you are replacing an 1-1/8" shaft with a 1" - just get the sleeve for the 8hp models or a B&S engine.
The B&S engines will not take the end pressure exerted by the manual pto clutch. They added a thrust bearing behind the drive pulley to make them work. On assembly you leave the drive pulley set screw loose and install the clutch. Then you apply the clutch to preload the bearing and then tighten the set screw.
Garry
  • caseguy said thank you
#5 caseguy OFFLINE
  • 1,628 Thanks
Posted April 19, 2011 - 06:23 PM
My mistake Gary! I should leave the details to the experts!
