How much fluid?
15 replies to this topic
#1 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 09, 2015 - 10:07 PM
For the life of me I can't find the tread about loading tires. So I have a set of 23-10.50 x12 ags that im.going to load with washer fluid how many gallons per tire??
#2 chieffan ONLINE
  • 11,386 Thanks
  • 7,127 posts
Posted November 10, 2015 - 04:05 AM
I got just short of 6 in each in mine, tubeless tires.
  • Alc and backwoods have said thanks
#3 KennyP ONLINE
  • 40,983 Thanks
  • 47,148 posts
Posted November 10, 2015 - 05:32 AM
Try this!
  • Alc, backwoods and boyscout862 have said thanks
#4 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted November 10, 2015 - 07:58 AM
I got 6 in my Deestone 23x10.50's. I just cracked the bead, stuck a big funnel in the side and poured away.
#5 KennyP ONLINE
  • 40,983 Thanks
  • 47,148 posts
Posted November 10, 2015 - 08:01 AM
That's the easy way if the beads seal easily!
  • TAHOE said thank you
#6 TAHOE OFFLINE
TAHOE
  • 8,310 Thanks
  • 5,804 posts
Posted November 10, 2015 - 08:07 AM
Mine had just been mounted and I told them to seat the tires, but don't pressurize them. When I got home, I was able to easily push the one edge down enough to get funnel in. :smilewink:
#7 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 10, 2015 - 08:10 AM
thanks guys i just printed the list
#8 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 10, 2015 - 08:17 AM
now on that list it says 7 gallons is that per tire im guessing
#9 KennyP ONLINE
  • 40,983 Thanks
  • 47,148 posts
Posted November 10, 2015 - 08:33 AM
Yep!
#10 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 10, 2015 - 08:35 AM
so 2 cases of washer fluid
#11 KennyP ONLINE
  • 40,983 Thanks
  • 47,148 posts
Posted November 10, 2015 - 08:57 AM
Depending on how you put it in, it may fluctuate from 6+ to 7 gallons per tire. Have fun!
#12 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 10, 2015 - 09:35 AM
Thatll be this weekends project a friend has one of those easy fill things were gonna try
#13 EricFromPa ONLINE
EricFromPa
  • 4,191 Thanks
  • 3,362 posts
Posted November 10, 2015 - 11:30 AM
Wish Washer fluid was Cheaper 15 or so years ago.You could pick up 4 gallon of the cheap stuff for $1 Yep 4 for 1 dollar.Now your lucky to find it under $2.50 a gallon.
Adds up quick when loading tires.Around $50 to load 23x10.50 tires.Still cheaper than Wheel Weights though.
  • propane1 said thank you
#14 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 10, 2015 - 11:48 AM
Cheaper then rim guard too. Lucky for me I work at Napa an get a price break
#15 backwoods OFFLINE
backwoods
  • 2,622 Thanks
  • 2,816 posts
Posted November 15, 2015 - 09:45 AM
ok there filled now but ive had a few people suggest toping off with air. has anyone done this an whats the point in adding the air?
