JD wont start
john deere garden tractor
6 replies to this topic
#1 case1man OFFLINE
case1man
  • 204 Thanks
  • 142 posts
Posted November 09, 2015 - 01:52 PM
Have a jd 112 1975 model pulled out of shed fine put on deck to mow leaves now wont start. No past problems always started well. Will crank over if you jump over the seloind but has no spark to plug. Jumped out safety switches still no go. I'm I missing something simple?
#2 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,262 Thanks
  • 6,071 posts
Posted November 09, 2015 - 02:03 PM
Sounds like you may have blown a fuse..  Look at the primary power wire that either comes off the battery + or solenoid's battery side terminal..  (the smaller wire)  Good Luck Pilgrim!
  • case1man said thank you
#3 Trav1s ONLINE
Trav1s
  • 3,578 Thanks
  • 4,551 posts
Posted November 09, 2015 - 05:34 PM
Ignition switch bad?  Will it run if you sent 12 volts to the coil and jump the solenoid to crank the motor?
#4 case1man OFFLINE
case1man
  • 204 Thanks
  • 142 posts
Posted November 10, 2015 - 10:54 AM
put new ignition switch in didn't help haven't found a fuse yet just looks like a fuse block and tried to bypass it with no luck.
#5 WNYTractorTinkerer ONLINE
WNYTractorTinkerer
    Tinker Master
  • 11,262 Thanks
  • 6,071 posts
Posted November 10, 2015 - 11:14 AM
Get a test light or meter and follow the + side through the Ignition switch.  You may just have an in-line fuse on the primary power wire.  Test it throughout the path and find the problem.  Also check the Ground side as it will also stop you up..
#6 BTS OFFLINE
BTS
    Make Stuff Up
  • 4,634 Thanks
  • 2,609 posts
Posted November 11, 2015 - 07:19 PM
Maybe it just doesn't like leaves?  :poke:
  • case1man and holdenboy1960 have said thanks
#7 case1man OFFLINE
case1man
  • 204 Thanks
  • 142 posts
Posted November 13, 2015 - 01:21 PM
Might have found the problem. Wasn't getting power from fuse block to amp gauge. Ran a jumper from fuse block to amp gauge and everything works. Will try to see if wire has a bad place in it.
Also tagged with one or more of these keywords: john deere garden tractor
