Bad boy zero turn mower
4 replies to this topic
#1 wayneslawncare.w OFFLINE
wayneslawncare.w
  • 1 posts
Posted November 08, 2015 - 03:47 PM
My zero turn has two hydraulic pumps the right side quit working and there is a ton of oil underneath the engine deck on that side. I'm assuming that the pump is shot or do you think the pump can be repaired or do I need a new one
#2 KennyP OFFLINE
  • 38,172 Thanks
  • 45,835 posts
Posted November 08, 2015 - 03:57 PM
:wave: Welcome to the forum! I haven't a clue about these zero-turn mowers, but I'd say a seal gave out!
#3 TomLGT195 OFFLINE
TomLGT195
  • 3,822 Thanks
  • 2,811 posts
Posted November 08, 2015 - 04:48 PM
:welcometogttalk: sorry no help here.
Edited by TomLGT195, November 08, 2015 - 04:48 PM.
#4 Cat385B ONLINE
    HAZMAT CAT
  • 13,966 Thanks
  • 9,997 posts
Posted November 08, 2015 - 05:03 PM
You need to find the exact source of the leak, it could be as minor as a hose, or it could be as major as the motor on that side.
#5 Eric OFFLINE
Eric
  • 1,323 Thanks
  • 813 posts
Posted November 08, 2015 - 05:47 PM
I would have to agree, have you started it and looked for the source of the leak? Hydraulic systems are very tough and usually the weak points are hoses and fittings. This time of year with cooler weather your fittings will get a workout while running and expanding can cause them to loosen and or fail. Just my two cents!
