rear weight setup on my gt20
14 replies to this topic
#1 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 08, 2015 - 09:58 AM
Just finished making a weight bracket. Attaches to the 3 point mounting pins. I used 10   2"x4"x18" solid steel bars for the weights. Somewhere around 350 lbs for the weights plus bracket. I think ill be doing well this winter.
  • Gtractor, wvbuzzmaster, KennyP and 3 others have said thanks
#2 wvbuzzmaster OFFLINE
  • 4,716 Thanks
Posted November 08, 2015 - 10:00 AM
Looking good.
#3 chieffan ONLINE
  • 10,193 Thanks
  • 6,657 posts
Posted November 08, 2015 - 10:37 AM
Good looking set up.  Been thinking of building something similar for my H16XL with a blade for this winter.  I have 5 - 44lb. suitcase type weights I could use.  They are old frame attachment weights for the Farmall H and M tractors.
#4 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted November 08, 2015 - 11:03 AM
I had planned on using suitcase weights but it turned out to be cost prohibitive. Where you already have the weights it would be ideal to use them.
#5 KennyP ONLINE
  • 38,474 Thanks
  • 45,969 posts
Posted November 08, 2015 - 11:04 AM
Nice set up! I like those weights!
#6 Cub 1650 OFFLINE
Cub 1650
  • 183 Thanks
  • 108 posts
Posted November 08, 2015 - 12:13 PM
Outstanding set up!
#7 JD DANNELS OFFLINE
JD DANNELS
  • 3,787 Thanks
  • 3,907 posts
Posted November 08, 2015 - 02:01 PM
Nice setup! They tuck in closer than suitcase weights would.
#8 KC9KAS ONLINE
KC9KAS
  • 5,389 Thanks
  • 4,692 posts
Posted November 08, 2015 - 03:27 PM
By gollie, that should hold the rear down for some traction!
#9 shorty ONLINE
shorty
  • 5,500 Thanks
  • 5,267 posts
Posted November 08, 2015 - 03:58 PM
Nice weight rack.
#10 Jimithin7000 OFFLINE
Jimithin7000
  • 11 Thanks
  • 9 posts
Posted December 11, 2015 - 07:46 PM
What a clever design. I have a 54 inch plow on my S-16H and had the best luck with just chains and wheel weights. I think that is mostly because the rack my neighbor let me borrow from his machine had a bar that goes up and around (think like a roll bar in a Shelby Cobra) and anytime I got on or off it it I would constantly smash my head into it.
I think the weights I have now are 50 per side and I also use chains and chain tensioners on the rear only.
#11 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted December 12, 2015 - 09:28 AM
I have 50lbs of wheel weights per side and the tires are also loaded with 66lbs each of rim guard (beet juice). I also run chains. Last year i found the wheel weight,  loaded tires and chains combo just wasnt enough with 300+lbs of snowblower hanging out over the front. So this year i decided to go all out and put more agressive tires on along with the added weight rack. A lot more weight is needed with the snow blower as opposed to a plow blade due to the massive weight of the blower.
  • shorty said thank you
#12 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted January 18, 2016 - 11:06 AM
I put my weight box on my three point hitch so it hangs off the back a bit further. Works great! Much better weight distribution for grip on the drive wheels!
#13 Gillis.jim OFFLINE
Gillis.jim
  • 285 Thanks
  • 162 posts
Posted April 21, 2016 - 09:41 AM
This machine keeps getting nicer and nicer every time I look at it.
How did your setup workout for you this winter?
#14 Curtis1480 OFFLINE
Curtis1480
  • 19 Thanks
  • 26 posts
Posted April 27, 2016 - 05:30 PM
We had pretty limited snow this year but, the few times I did use it i couldn't find an incline it wouldn't crawl right up! It made an incredible difference, very happy it. I have found however that it is way too much weight when the blower isn't on there, guess ill have to pull a few weights out and replace them with a block of wood until the blower goes back on.
Edited by Curtis1480, April 27, 2016 - 05:32 PM.
  • Gillis.jim said thank you
#15 Scrapr65 OFFLINE
Scrapr65
  • 22 Thanks
  • 24 posts
Posted January 14, 2017 - 10:53 AM
Nice set up and excellent job :thumbs:  :smiley-score010:
