Walbro pump HELP!
11 replies to this topic
#1 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 02:08 AM
Pump Image.jpg I finally received the kit for my K10-WIP fuel pump but...there are no installation instructions.  Anyone installed one?  I am lost.  Went on line and found a smattering of information but also found the info was not 100% correct.  One thing that's required is: there are rubber nipples protruding from the backside of the check valves. I installed each valve as the old one was removed so was sure that part was right...I believe.
Now, there was also a small rectangular sponge included which I assume to be a filter. But there is no hole in the opening anywhere for it to be filtering anything.
It's all in a pile on my desk right now pending a response from someone who knows what I have and can tell me how to go about what needs to be done.
Taking my pounding head to the pillow for now.
Thanks for any help.
Edited by Phluphy, November 08, 2015 - 02:11 AM.
#2 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
Posted November 08, 2015 - 06:17 AM
this is what is in the Walbro Parts and Service Manual.
Attached File  walflpmp.PDF   611.87KB   92 downloads
Edited by drbish, November 08, 2015 - 06:22 AM.
  • MH81, KennyP, boyscout862 and 1 other said thanks
#3 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 09:16 AM
attachicon.gifwalflpmp.PDF
Man you saved me with this. First thing this morning, after getting my coffee, I studied all the parts and with a bit of common sense realized what the arrows on housing meant and put it together, still not sure it was being done correctly.  Then I checked here and found your diagram.  It appears I did it right but, it also appears I am missing three parts.  #'s 5,6,14. Those were not seen when the pump was initially disassembled, I did it on a white towel so nothing would be missed nor be able to roll away. Think they are important, were there, ever there? There are no impressions on the diaphragm indicating their presence.
Any clue what the purpose of the foam block is?
Thank you.
Never mind. My BAD! Just realized the pdf link and, going through it, shows the parts were not there for the WIP 15.
Thanks again.
Edited by Phluphy, November 08, 2015 - 09:29 AM.
#4 KennyP ONLINE
  • 41,519 Thanks
  • 47,425 posts
Posted November 08, 2015 - 09:23 AM
Look at the pdf he posted. The foam is an air filter.
  • Phluphy said thank you
#5 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 09:33 AM
Yepper, did that, but still not clear as to how air is intended to enter the space when there is no outlet...at least i'm not seeing one, even with a jewelers loupe.
#6 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 09:35 AM
Out to install. Hope it works, been down for weeks. Thanks guys.
#7 drbish ONLINE
drbish
    Collecter
  • 1,576 Thanks
  • 1,374 posts
on the last page of the download the wip-15 pump does not show them parts in the part number list so i guess they are not in that pump,it states this pump was made for american yard
#8 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 11:22 AM
Back to square 1.  Nothing! Pulled outlet side of filter off, dropped it down below tank level, gas came out, the filter was full.  Hooked it back up, cranked about 3 times @ 5 seconds each...nothing. Suggestions?
Going back out to add a direct shot to intake of carb to see if it fires.
Edited by Phluphy, November 08, 2015 - 11:24 AM.
#9 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 01:09 PM
Didn't do the gas in the carb thing but did put vac gauge on inlet side of pump...pulled around 5 inches mercury, from what I interpret.  Wondering if the line from tank to pump has a crack,cut, hole worn in it...it'll pull air before liquid from past experiences with vacs.  Back to tracing fuel line, taking off tank etc. Back later.
#10 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 04:15 PM
It lives!  After taking everything apart, fuel tank out, doing a vac check on the line the problem was found...back where I first started.  The line was cracked majorly at the outlet end of the filter. At least I now know how to take the fuel tank etc. out. Replaced the filter to pump line cranked several seconds and it fired up good as ever.
#11 KennyP ONLINE
  • 41,519 Thanks
  • 47,425 posts
Posted November 08, 2015 - 04:40 PM
Glad you got the issue solved!
#12 Phluphy OFFLINE
Phluphy
  • 309 Thanks
  • 401 posts
Posted November 08, 2015 - 05:45 PM
Thinking cracked fuel lines were the issue with loping etc. all along. Eh, at least it has a rebuilt fuel pump, new filter, fuel lines.  Thanks again.
