David bradley spring clutch
4 replies to this topic
#1 michaelgoodwin_47 OFFLINE
michaelgoodwin_47
  • 2 Thanks
  • 9 posts
Posted November 04, 2015 - 11:57 PM
I recently got a db garden tractor clutch will not disengage, any suggestions?. It has a spring style clutch not a ball lock. I have took it partially apart to clean clutch disk but never took out clutch bearing and spring. Could bearing be bad if so where possibly could i find one?
#2 Alc ONLINE
  • 7,112 Thanks
  • 7,526 posts
Posted November 05, 2015 - 06:23 AM
Welcome to GTTalk !  I have some info that I thought would help but it's for the ball lock clutch .  I've never had a problem with my tractors that have spring clutches and only once had the clutch apart on the sickle bar which is supposed to be the same spring clutch . Have you downloaded the manual for it yet ?
#3 crittersf1 OFFLINE
crittersf1
    GT Lunatic
  • 4,208 Thanks
  • 5,807 posts
Posted November 05, 2015 - 08:03 AM
:welcometogttalk: :camera:
#4 michaelgoodwin_47 OFFLINE
michaelgoodwin_47
  • 2 Thanks
  • 9 posts
Posted November 05, 2015 - 09:40 AM
Yes I have downloaded the manual and read it many times. When I go to start the tractor it want to move forward. Having trouble finding info on the spring clutch.
#5 Alc ONLINE
  • 7,112 Thanks
  • 7,526 posts
Posted November 05, 2015 - 11:38 AM
Could the clutch rod be  way out of adjustment ?  Maybe trying it without  the clutch rod and seeing if it binds while pulling it back to release the clutch . It takes a pretty good pull to release the clutch .
